18x9 +18 offset on 265/70/r18
SoCal87
Stephen
San Diego CA
2019 Ford Ranger XLT
I’ve searched so forgive me if I missed your post/picture, but I am looking at the method 705s in 18x9 with a +18 offset and going to run a 33 in 265 on it. Anyone have some pictures they could share? Just want to see how much if any of the wheel pokes out of the fender.
TIA
pickettf3nce
Troy
Arizona
IS Manager
Here's a good reference for you.
If my math is correct, your poke would be approximately -2mm less than below. (Obviously dependent on tire tread pattern, side wall design, and such.)
Mine: 265/70r17 on a 17x8.5 +10mm wheel
Yours: 265/70r18 on a 18x9 +18mm wheel
If you want to do some further comparison, check out "Will They Fit"
ScarzRanger21(2.0)
Eric
Auberry, CA
Electrician
I run +12 but the difference in millimeters is less than 1/4”, hardly noticeable. The “poke” will really depend on your tires and tread shoulder. I run 255 width which are about a half inch narrower, 1/4” on each side. If you’re running a wheel with 1/4” difference in offset and 1/4” wider tires, your setup will pretty much match what I have as far as sidewall sticking outside the fenders.
TxOTRRanger
Clay
Elwood, Texas
Mine are the +20 offset on the stock size tires.
Highway flyer and occasional gravel road runner lol.
