OFC Ranger
- Thread starter
- #1
Had a chance to start on this today. I was originally going to go the super cheap route and do 2" EMT conduit tubing, but decided to go with aluminum 1" square tubing. Right now front is supported by quad neoprene stoppers while I decide how I want to approach that. I'm leaning towards using a wide U-Bolt with adjustable feet to adjust the tension as needed. While I plan to run a roof solar panel and some off road lights up front and keep all the weight towards the back, I don't want it to have unlimited flex. I also plan to lay down pressed metal paneling (aka patio furniture grating) so me and my daughter can use it as a platform for long distance shooting.
The rack will extend to the back, but the rear portion may be designed a little different and that is why I did not run one piece from front to back. I will be running cross bars every 6 inches because I like over-engineering when I can.
Some of you may be familiar with 80/20 extrusion builds. I'm doing a hybrid. My bars will be standard aluminum, but I am using 80/20 brackets and connectors without the t-nuts and installing the bolts directly in with sealant and red locktite. All open ends will be filled with expanding foam and capped.
Temporary it will be finished with self etching primer (after hitting everything with a drill wire brush) and underbody rubberized coating, but will take it to get something like LINE-X down the road.
I think my end total will be under $300 dollars.
My 80/20 stuff should be here tomorrow (I love me some Amazon)
