Warning about Rough Country 2.5" Leveling Kit
DMac
2019 Ford Ranger Lariat
I have found a safety issue with the rough country 2.5" leveling kit though. I contacted rough country about it and then called back this morning to see what the engineers had said/found.
I had my leveling kit installed last Monday at a local shop who has a very good reputation, and who does good work. I drove the truck back and forth to work (30 min. Drive) for the week with no issues I noticed.
Saturday I drove the wife to Birmingham (1.5 hr. drive) and just as I exited the interstate, luckily slowing from 80mph to 20mph on the ramp, my front end went crazy, trying to pull left into oncoming traffic as I was making the right hand merge turn. I fought it over to the right hand side of the road in a construction zone and got it stopped.
When I looked at the front end, the passenger side tie rod had worked loose and came free. The threads on the ball joint were a little marred, but no damage had occurred. Of course I had a short stomping/cussing fit, then I walked the 45 min. in a thunderstorm to AutoZone and bought enough nuts and lock washers to insure I had the proper thread style, then walked back and repaired it and went home.
I took everything apart once home and checked the torques on everything, and paid close attention to the surviving tie rod end. Everything was up to spec's. Also, I inspected the tie rod that came loose for signs of faulty install (stripped threads, cross thread, etc.) and found nothing. But I did find the flaw.
The mechanic followed the install instructions from rough country to the letter. The problem is that whoever wrote them specified that you "retain the hardware" for the reinstall. Back in the "castle nut/cotter pin" days that was fine, but the 2019 Ranger front end doesn't have those, they use a version of a Nylok nut, which has the nylon retaining ring at the top.
A Nylok nut is a one time use nut, once loosened or removed, you should replace the nut, because it no longer safely holds torque. The mechanic didn't notice because he was following the instructions, I didn't notice it because I didn't check their work, and probably still would have missed it once installed.
Anyway, the guy from rough country told me this morning that the engineers said they are going to start including two new nuts for the tie rod ends. When I asked if they were going to contact the folks who already purchased the kit, I really never got a definitive answer, which is why I'm posting this here. I know it won't reach everyone, but if it saves someone from a wreck, then that's something, because I almost went diagonally into cross traffic, and the pucker factor was crazy high.
Pass this around please, so people check their installs. Those nuts are sold in pairs from Ford, pick some up and be safe.
Thanks
RJohans
Bend, Oregon, USA
2019 Ford Ranger Lariat 4x4 Supercrew Sport
Wow! Thanks for sharing!
Andy
Andy
I planed to use blue locktite on all the fasteners I loosened just for this reason. I did ask Rough Country if they would send me new tie rod nuts and they said no. That’s nice.
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
I don't have this particular kit but I guess I'll go back and add a drop of Loctite to all the fasteners R&R'd.
DMac
DMac
See, that's what bothers me. I was only calling them to make them aware of the Nylok nuts and make sure that others didn't have any issues. I wasn't asking for a rebate or pitching a fit, I just felt like they should know and prevent possible issues.
If I had actually wrecked, I might have gone a different directio.
Regardless, the business who did the work were stand-up guys about it. I took it to them the next morning and they ordered a new tie-rod end, 2 new nuts installed, inspected and realigned without so much as a cross word.
Them, I will use again. Rough country, most likely not, just for the way it's been handled. A mistake I can understand and forgive, but once you know it's a mistake and don't fix it, that I cannot abide.
RCMUSTANG
Ray
Los Angeles
I hit everything with my impact gun though. I'm probably good. Loctite wick for insurance.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
2016 Focus RS, 2019 Ranger SCrew Lariat FX4 Sport
It looks like BDS may have taken notice as well, they pulled down their lift kit from the site without any explanation. I took a look at their instructions while they were still up though and they also said to reuse the tie rod nuts.
NateS415
Nate Schroeder
Cleveland, Ohio
Ford Ranger
Anyone have a part number or size for the nut in question? Kits in the mail and would like to get all necessary parts before starting.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
Jrye22
Jon
New Jersey
2019 ranger lariat
Anyone know the exact nut size and thread I rather go to like a Lowe’s or Home Depot
NateS415
Nate Schroeder
Cleveland, Ohio
Ford Ranger
What does everyone think would be better? Adding some Loctite or a new nut?
RCMUSTANG
Ray
Los Angeles
Loctite.
rangerdanger
SF Bay Area
j0shm1lls
Josh
SoCal, USA
www.youtube.com
New nut AND Loctite?
EDIT: Actually don't do that! Apparently they don't play well with each other. I'd just go the route of what the Manfuacturer suggests - New Nyloc Nut (NÂł).
