Unlock all upon driver exit
EJH
Ed
Subarus, 2021 Ranger
On your steering wheel, use the buttons to scroll to SETTINGS>VEHICLE> LOCKS and choose your options.
This is correct. My truck will unlocks all doors and the tailgate after the driver turns the engine off and opens their door.
redone17
Cold Spring, NY
2021 Bronco Black Diamond, 2020 Ford Ranger Lariat
So, there isn’t a way to setup all doors unlock when driver door is opened and ignition is on? The ignition has to be off?
I was able to set that up in the Bronco it’s super convenient. It’s starting to drive me a little bananas when I go to open another door or tailgate and my key is in the console or otherwise. I gotta walk back and hit the button on the door or procure my FOB.
From The Manual - No, Door Unlock (Auto) Will not Unlock if Ignition is (On)
I think due to safety (Car-Jacking) - (Children)
Now, there may be a Forscan setting - To Modify This (IDK)
Auto-Unlock
NOTE:
The doors do not auto-unlock if the vehicle has been electronically locked before the driver door is manually unlocked.
The auto-unlock feature unlocks all of the doors when all of the following conditions have been met:
  • All the doors are closed and locked.
  • The ignition was on. ----- (Keyword - WAS)
  • The vehicle was shifted out of park and a speed greater than 20 km/h (12.4 mph) was achieved.
  • The vehicle has come to a stop.
  • The ignition transitions to accessory or off and, within 10 minutes, the driver door is opened.
The auto-unlock feature can be enabled/disabled through the message center.
However - I forgot about this setting (Custom) in the IPC - Lariat Cluster, should be same for XL/XLT
Settings - Vehicle - Locks
You have selections here to (Check) or (Uncheck) - Auto Lock & Unlock
Now this should turn off the Autolock function by Unchecking the box
