Under Cover - Ford (ML3Z-7222-E)
jmkiser
Anchorage, Alaska
2021 Ford Ranger Lariat FX4
Data/Telecommunications
Would anyone happen to know of a great aftermarket replacement for the flexible panel that needs to be removed for the oil change on a 2021 Powerboost? I'm getting tired of removing the four 8mm bolts and having the thing fall into my face every time. I've been looking on line for a decent, reasonably priced alternative, however I haven't been very successful.
My current plan is to buy an OEM replacement that hasn't been torn up yet and use the existing one as a guinea pig/template to figure out exactly where I need to make the access hole then install the new one. I only need a small access place since I upgraded the drain plug from OEM to a stahlbus oil drain valve…
jmkiser
jmkiser
Anchorage, Alaska
Yes, and so sorry for the delayed response.
My personal vehicle is a 2021 Ranger Lariat and I had my girlfriends F-150 in my head when I posted this by mistake. I couldn't figure out how to delete it so I just left it with hopes that someone might be able to assist, know that you're all probably Ford enthusiasts.
I looked at the Talons Garage website and they are extremely proud of their products, not including shipping!
John from Alaska....
Willier
Will
New Jersey
2019 Ford Ranger Lariat
Logistics consulting
Some have replaced the fasteners. Mounted nurserts in th3 fender and added ss nuts and washers to facilitate oil changes..
jmkiser
jmkiser
Anchorage, Alaska
Correct, sounds like what I'm looking for. My only other option is to use the existing felt/flexible/pliable OEM one pictured and then create my own access hole by trial and error.
Willier
Will
New Jersey
If you were closer you could 7se my nursery kit!
Willier
Will
New Jersey
Nutsert!! Fricking autocorrect!
jmkiser
jmkiser
Anchorage, Alaska
Oh! now I see what you are meaning. Great idea, I will have to look into that. I have a place called Fasteners & Fire Equipment Co. here in Anchorage, they would probably have that. I'll check them out today! Right-on, thanks man....
