TPMS pressure range
JCMAC
Richmond Ontario Canada
2019 Black Ford Ranger Lariat FX4, Sport Pack
Retired Systems Analyst
I have removed the OEM LT tires that came on my truck. The TPMS wont let me run the new standard load tires at their recommended cold pressure because LT tires require much higher pressures to carry the same max load.
I want the tire pressure range to be changed to match the new tires. How does that get done?
I think Forscan IPC , has a setting to change it.
The exact Hex-Line for it is: IPC 720-04-01
JCMAC
JCMAC
Anyone know what to change it to so that I will get a Tpms warning for a low pressure in the range of 24 psi.
