This Thing Was In My Way…….
Oh whew! I thought this was going to be another tranny thread... But the first pic does looks like there's blood involved.
RK Racing
Hawthorne, Ca.
2023 Lariat 4x4
Toolmaker
Here are some of the cuts that are needed….. if you are squeamish about cutting into your frame, this lift is not for you :)
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
Man, there is a level of commitment for that one! They do look good lifted to that height though, follow a dude on IG. I wouldn't but looking forward to when you post completed pics.
1pt21gw
West Coast
Ye' Ole Traveler
Very Cool! ~ This is not for the light hearted. I remember my first week with mine and freaking out over drilling a hole to add mudflaps.
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
I am from Ford and I think you have literally cut the testicles off of your truck. ?
TJC
Before it's over you are gonna need that $12K NextGen Transmission! They go as high as $15K
For your reading pleasure....
- Top 5 Benefits of an Upgraded or Built Transmission
- Calculating Torque Multiplication Factor, Why is it So Important?
- Top 5 Ways to Extend the Life of a Factory Transmission
Here's the summary of the TMF topic (#2) above - In the example below they went from 31.5" to 37" tires, but it is only 1 of the 4 factors that enter into the equation. Doing the math will tell the story.
Now for the fun (and heartbreaking) part. Using the Commutative Property of Multiplication, our ability to multiply factors in any order and receive consistent results, we must multiply the TMF of the preceding 4 steps in any order. The formula we use is as follows:​
A • B • C • D = E
1.199 • 1.175 • 1.22 • 1.375 = 2.363
TMF (E) = 2.363
Key:​
A - Differential Factor​
B - Tire Factor​
C - Mass Factor​
D - Power Factor​
E - TMF​
In this case, the example truck began life with 800ft.lbs. of torque. Upsizing tires, deleting the truck and simply having a heavier trim selection more than doubled the applied torque of this truck compared to an unmodified base model. Below is the formula for calculating applied torque using your TMF:​
A • E = N
800 x 2.363 = 1,891
N = 1,891ft.lbs. of Torque
Key:​
A - The Amount of Torque Produced from the Factory​
E - TMF​
N - Applied Torque at Crankshaft​
Conclusion:
By simply rationalizing our easy to calculate TMF to our factory torque rating, we can accurately identify how much torque is actually being applied to our drivetrain components. This is a critical metric for understanding the right transmission parts for our personal application.​
It is imperative when researching a transmission or transmission modification to understand at length how this concept works because vehicles (specifically diesel trucks) with TMF’s in the 1.1 to 1.4 range tend to have substantially shorter lives, with vehicles in the 1.5 and above range being exceedingly more likely to fail within their first 150,000 miles. Vehicles above a factor of 2 are generally only alive due to the conservatism of the driver or the infancy of the power.​
Rinn69
N. Central Iowa
Retired USAF MSgt
Frame warranties are over-rated anyway..... ?
