Tail light removal
Hbombed
Heather
Peabody ma
2019 ford ranger xl supercrew
Has anyone detached the tail lights yet? What’s the best way to disconnect the whole tail light?
Hi Heather,
Very easy....I had both out when wiring my Ranger for towing behind the RV. Access the two bolts with the tailgate down and gently pull out and the whole light assembly will easily remove.
Hbombed
Heather
Peabody ma
Hi Heather,
Thank you! I was able to remove them but need to disconnect the wiring as well. Not sure the best way?
Hi Heather,
I had to remove and found it easiest to disconnect from the frame connector. I left the "jumper harness" attached to the tail lights. Not sure if this helps you...
Hbombed
Heather
Peabody ma
Hi Heather,
Thank you! I think I attempted that but couldn’t quite get it. I’ll try again! Thanks for your help!
Tumbleweed
George
Bedford, Texas
2019 Ford Ranger 4X4
I am in the process of adding auxiliary taillights so I can flat tow my 2019 4X4. I do not want to splice my factory wires so I was looking into the LED lights from Blue Ox that apparently all you have to do is drill a 9/16" hole in the back of the taillight assembly. This will bypass the vehicle system and sounds easy to do. I only have 1 bulb in the back of my taillight ( don't know how to get it out) and I think its LED. I wonder if there is any issue with drilling a hole in the allotted space.
Superdannyboy
Hi Heather,
Yea I'm having a hard time removing the connection at either end.
Darnalle
Eric
Ford Ranger Tremor 2021
PMHNP
When you take off the brake light, there is a connector that has a red slide tab/lock, slide it out, depress the tan plastic distal to the red slide, and gently tug. It’s loose.
Superdannyboy
Took some frijoles to get it loose but I got it
