Steering Assist Fault - Service Required
trmkars
Tyson
photos.project395.com
2020 Ford Ranger
IT Stuff
Has anyone else seen or experienced this issue? "Steering Assist Fault - Service Required"
With 109k miles on my Ranger (many of them in rough conditions) -- I received this error message on the highway just north of Vegas. I just filled the tank and driving like normal and this message popped up. I could feel something with steering was different.
I didn't show any error codes, I was able to clear it a couple times by disconnecting the battery but the issue returned within 30 minutes of driving (again just normal highway driving).
I ended up pulling the power steering assist fuse. Completed my trip to Nevada, and returned home.
After being home and couple days and way more research I was ready to really troubleshoot the issue and fix it. I put the fuse back in and now everything is normal again. Now at 110k miles.
It's been several weeks - no sign of any issues.
(now I did have a prior incident with steering a year and half ago, so I suspect issue is related to steering angle sensor in the column)
Well let me know - has anyone else dealt with this before?
Thanks
RangerBill
Thanks
Use a code reader such as Forscan and retrieve the codes. There should be stored codes for this message appearing. Many cheaper code readers won't read all modules in the truck.
trmkars
trmkars
Tyson
2020 Ford Ranger
IT Stuff
I do have a Forscan reader, so I will have to give that one a try. I was/am using a bluetooth scanner that others here have used in the past and I paid for the upgrade to see more PIDs or something.
Okay, I will try using Forscan. Thanks RangerBill!
This is one of those - fault messages that may not show a code (history) unless it is an active fault - so if it pops back up, scan before cycling the ignition.
NotBudule2
21 Ranger
Can you suggest a reasonably cheap code reader that will read all the important stuff? I hate to pull the trigger on one and find out it didn't do all thats needed...
RangerBill
I use Forscan and their recommended adaptor listed on this web page:
https://forscan.org/home.html
It runs on a Windows computer and seems to be able to see DTC codes from all the modules in the Ranger. It is the one I use. The software is free to read codes.
Definitely get it checked. Best case scenario it's a loose connection like a ground or something(had that happen with a Nissan Altima with the Electric Power Steering Pump. Yes that is a thing). Worst case scenario it's a faulty rack and pinion.
NotBudule2
21 Ranger
So you don't need a "handheld" scanner, just the adapter that hooks to a laptop and forscan ? I was under the impression that a "scanner" (handheld with its own screen) was still needed even with the adapter and forscan and have been hesitant to buy anything...
ForScan is a neat tool that also does Scanning Specific to Ford Lincoln Mercury Vehicles. You can do quite a bit with it. Of course there are still limitations like updating the PCM with a Factory Update, but you can still do quite a bit. It's worth having if you have a Ford Vehicle and don't plan on switching.
RangerBill
A Windows computer (laptop), Forscan program, and the proper USB adaptor is all you need.
Yes - Forscan is a great for - Code Reading & As-Built (Customization) but it has some limitations as far as - T-Shooting Live Data - PID viewing and Bi-Directional - Testing.
It lacks the full PID database and even then, its cumbersome to get the PID display you want.
It requires a manual selection vs loading the full PID display automatically (in each module)
Forscan - shines over all scan tools including FDRS as it allows easy - As-Built data changes. This is its main function.
RangerBill
I would say a main function of Forscan is reading DTC codes. It is very useful for that purpose.
trmkars
trmkars
Tyson
2020 Ford Ranger
IT Stuff
Thank you everyone for the input! I will update if/when I learn something else with this issue.
