Spotify How do I ?
OregonRangerTremor
Craig
2021 Ranger Tremor/2022 Bronco/2006 ChargerDaytona
Retired LEO/Dog Trainer
OK, I am an old fart....help me out. Old but not stupid either:like:.
I have a Spotify account and songs downloaded.
I have a 2021 Ranger Tremor Lariat and I use an android phone. I believe I have Synch3.
HOW DO I PLAY SPOTIFY SONGS FROM MY PHONE IN MY RANGER?
Do I need a USB cable with Synch3? (My Bronco has Synch4 and I think on the Bronco it will be wireless).
So please help me rock out in my Ranger.
THANK YOU!!!
Bob902
St. Louis
2021 Ranger XLT
RETIRED!!!!
THANK YOU!!!
I have car play. As soon as I plug my phone in, it appears on the Sync screen. If I remember, the first time I had to open it on my phone but since then it appears automatically.
RangerPNW
Thomas
Santa Fe, NM
Project Manager
THANK YOU!!!
Yes you'll need the usb cable. Just plug it in and you'll switch over to android auto, and from there you can use spotify.
Dr_Strangelove
Adam
Henderson, NV
'22 XLT Supercrew 4x4
Art, Design, Photo & Video
I'm also an Android user - I recommend you do it Via USB cable. I have this one. (Click blue text for Amazon link - the link was very long.) Here's the 5 foot version if you would like a longer cable.
You don't have to buy these cables - however - it is VERY important that you buy the proper "data" type cable otherwise you will not be able to access Android Auto. You will only be able to charge your phone.
When you plug in your phone you will be prompted to set up Android Auto for the first time on the Sync3 unit.
You will be able to access Spotify through this interface.
THE OTHER WAY to do it is to simply choose "bluetooth" via your radio source menu and connect your phone over bluetooth - and simply play Spotify on your phone.
I recommend the first method as it is much safer to operate your Spotify playlist with the radio head unit instead of using your phone. Not only would you have to use your phone to control the radio with bluetooth - it drains your battery. The first method is plugged in and maintains if not charges your phone battery.
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
The first time I tried to connect mine I had a crap cable and it would only charge.
Then more recently I had a cheap data cable go bad.
It's sorta picky for sure.
OregonRangerTremor
OregonRangerTremor
Craig
That cable will fit the Android phone? Thanks for all of that information!
OregonRangerTremor
OregonRangerTremor
Craig
Thank you everyone for the information!!!!!!
Dr_Strangelove
Adam
Henderson, NV
Yep! One end is USB-C But it's at a right-angle which makes plugging into your phone while it's laying in the USB tray much more "ergonomic". The other end is USB-A for plugging into the truck. I use the shorter 1.5 foot one I linked but I also linked the longer 5 foot version. The 1.5 foot is a little snug but I like that. Cheers!
OregonRangerTremor
OregonRangerTremor
Craig
Heh thanks a lot. And to everyone; thanks....I be damned...IT WORKS! I will buy the better cable too.
ROCK ON!:clap:
P-38Ranger
San Diego
2022 Ranger Lariat
The key that I discovered is that the car play will nearly never know what you want to do, so you have to select it on the truck screen. I used both. Wake and Goggle, and if the last time I used Goggle, and I have Waze on my phone, it still shows Goggle. So I have to switch to Waze on the truck screen. Took me nearly a month to figure that ouT!!!
mjdaniel
Temecula, CA
2023 Ford Ranger Lariat
Go to your settings on your phone and turn on bluetooth. You can use this method if you don't want to use a cable.
Trustable
4Runner
As everyone else said just plug it in and android auto will display and you can select Spotify on the screen. One thing that has made my life easier is I bought a 1ft cable (vs standard 3 or 6) it makes my phone fit in the cubby much easier. For cables I recommend the anker brand. They have a good return policy if they stop working. Only downside is you can’t use pick up and use the phone while plugged in, but I don’t do that while driving anyway so it’s not a big deal.
