Yeah but you have super fancy Roush seats don’t ya.
Did this go over the existing rubber? Or did you have to remove the rubber first?Actually I purchased both the leather cover and this carbon fiber. I installed the carbon fiber and really like it. I rest my hand on the shifter a lot and it is smooth and comfortable. If you install one the instructions recommend you use stronger double sided tape. I just thoroughly cleaned the existing area with acetone and applied the cover as is. That was 6 months ago and have not had any problems.
https://www.amazon.com/ruihe-Carbon...r+gear+shift+knob+cover&qid=1744210085&sr=8-9
That’s a good question. I’d like to know aswell.. looking at the product as close as I can (via pictures available on Amazon.) it appears to be overlays that adhere to the original material fixed in those locations…(looking at the carbon fiber one.).. so you may have to adhere the pice that came off back to the shifter (or inside the overlay CF piece.. then glue it back on to your shifter.Did this go over the existing rubber? Or did you have to remove the rubber first?
It easily fits over the existing rubber on the shifter. Like I mentioned I cleaned the entire area rubber with acetone to remove any oils from my gripping it and applied it as it came. It has held tight.Did this go over the existing rubber? Or did you have to remove the rubber first?
Care to share a link for the replacement part? Mine is falling apart and I cant seem to find it on the parts website....I ordered the little rubber trim from Ford’s parts website for about $10 and it fit perfectly. Took around a week to get. You can also check eBay or Amazon for a generic trim kit if you want it faster.
