RSI Smart Cap Questions
MickeyG
Canada
2020 Ranger
Thinking about picking one of these up but I have a few questions :
Do you have to add a leaf or beef up the rear suspension at all?
Do they have a big effect on mpg?
I've never had a camper shell on a truck, does the rearview mirror become useless?
Thanks in advance
Colo_Ranger
Thanks in advance
You don't need to beef up the suspension. Its not that heavy. No heavier than a normal topper.
No change in mileage.
Rearview is decent. You loose some, but... you can still see.
gwhalin
Greg
New York
I actually did and up replacing my rear shocks with beefier ones in my Tremor. Found that I lost around an inch in the rear and was hitting bump stops more than I liked after the cap (I also carry probably 50-60 lbs in the bed). I put Deaver HD Expedition leafs on and am very happy with my decision. I also would say the rear view is pretty useless so I added a wolfbox dashcam with a rear camera.
Brett Fields
Brett
Brooklyn
Paramedic
I went with Icon leafs and Bilstein 5160's. It's probably a safe assumption that if you're putting on a Smartcap, there's something in the bed to cover, something on the top to carry, or both.
FYI, 80-20 extruded aluminum makes killer crossbars. Don't get sucked in to overpriced silliness.
BladiRanger
Bladimir
SoCal
2020 Ford Ranger FX4
Electronics Hardware Engineer
Did you need to install a J braces or brackets? I heard that on 6G Ranger they need to install those braces for anything heavier than 88Lbs.
RangerPNW
Thomas
Santa Fe, NM
Thanks in advance
Being in the great white north, I've seen several reports of issues with the latches on the RSI smartcap in the cold/snow. Might be worth diving into before pulling the trigger.
I have a Leer canopy, and i will say the rearward visibility decreased quite a bit, but i've mostly adapted to it. One perk to the Leer option I got however is the rear latch is integrated with the electronic tailgate lock. Really like not having to pull out a seperate key to get into the back. The side windows still need a key, but nice to have the main one linked with the main locks.
gwhalin
Greg
New York
The latches on my Smartcap did initially have problems with getting gunked up in winter months. I installed some aftermarket covers for them and occasionally hit them with some lubricant and that keeps them working great.
RangerPNW
Thomas
Santa Fe, NM
Can you post how you've got the rear camera mounted? Looking to do the same on mine. I'm also on the fence about the Deaver expedition leafs as i'm running into the same issue with blowing through travel, but i was thinking it was just my Fox 2.0's being useless (which they still might be)
gwhalin
Greg
New York
I have the crossbars on top of my cap for hauling my kayak. Ran the rear camera cable through the vent behind the rear seat and mounted the camera on the bottom of the rear crossbar.
I have Fox 2.5s on my truck and had a fair amount of sag (I took measurements from ground to wheel well at various stages of my build) after the cap was put on. The Deavers have me back to factory ride height.
RangerPNW
Thomas
Santa Fe, NM
Ah that makes sense. I'm looking to try and do something without installing cross bars on my cap... might have to get creative then.
Maybe i'll try the deavers then before i swap out the Fox 2.0s, i quite liked them before i put the cap on so reason stands i might like them again after the new leafs (unless of course the wife gives me approval to get an F-150, growing family and all that)
bmidd
Chattanooga
2020 Explorer ST 2019 Suburban
Worker Bee
Had the SmartCap installed yesterday. This picture is loaded down with ~400 of tools and Packout boxes in the back, still sits decent. I ordered some RoadActive leaf spring helpers and the roof rack for carrying ladders will be here this week too. i used to have a Truxedo LoPro and Elevate rack on the back, it was ok, but the LoPro let so much water in and I was tired of rolling and unrolling multiple times a day. I missed my Suburban and Sequoia for keeping tools and equipment dry.
