Removing rear plastic wheel well covers?
FiveChime
Matt
Baltimore
Worker bee
Hoping someone can help me. I want to remove the plastic rear wheel well covers but there are two pair of these rivets I’m not sure how to Properly remove.
Are there any other oddball things to be aware of?
Thanks
ParkerAzJeff
Parker Az
1994 Ranger 2019 Ranger
Pop rivets aren't removable unless they're drilled out, cut the head off with a chisel or grind them off.
FiveChime
FiveChime
Matt
Baltimore
Worker bee
Thanks i just don’t get why ford wouldn’t make that part removable easily.
Hi Matt,
It is most likely not regarded as a serviceable part in normal maintenance by the dealer or the owner. You are the first person on these forums I recall wanting to remove.... Thousands of posts and this is a first as I can recall. Other members chime in on this concern?
Sandman Ranger
Pete
Lead Process Engineer
Glad the Ranger has then.
Well protected compared to many full size trucks with metal wheel wells exposed.
JaysOnTheEDGE
Jay
I drilled a hole into mine for the mud flap install it’s just a big open space between the wheel well and end of bed. I image it’ll be full of dirt and mud if it was removed it completely
FiveChime
FiveChime
Matt
Baltimore
Worker bee
I have galvanized rivnuts installed on the Metal part of the wheel well to bolt things to inside the bed and wanted to paint the underside, which requires gaining access behind that plastic panel.
If it doesn’t let water back in there I guess it should be ok?
slowmachine
New Hampshire
You’ll never convince me that water can’t get past the liners. The turbulent air flowing through there at highway speed will carry any water or dirt wherever it flows. Aside from that, you can still remove the rivnuts and work through the holes to treat the back side without removing the wheel well liners.
FiveChime
FiveChime
Matt
Baltimore
Worker bee
I imagine moisture would get back there too, but how do you remove a rivnut without drilling it out?
I’m about to get line-x put down in the bed.
jss81258
Fixed equipment inspector
A grinder will also work.
