Owners of 2019 Ranger Lariat FX4 ---- I NEED HELP
Fish
Roger
Hershey, PA
2019 FORD Ranger Lariat Hot Pepper Red, 1993 F-150 XLT
HVACR
Because of the install of a Roush tune I no longer have my factory stock tune. The complicating issue is that since I have had the Roush tune installed, when I am in Trail Control it throws a fault code putting the truck into limp mode. Making a long story short, I spent $ 240 & a number of days with Ford having my truck in an attempt to load the factory stock tune with no success. I am currently using an nGuage to load custom tunes from unleashed, which is Great, but I still get faults in Trail Control and I don't have the original factory stock tune so with exception, according to ford engr, of having ford install a new PCM module to get back to stock @ $ 650, I end up with having no stock file and can't use my Trail Control.
I can load tunes using my nGuage. So to get as close as possible to a stock file, I'm asking this.
If someone out there owns a 2019 Ranger Lariat having the FX4 package and is using the hp tuner nGuage. My truck was built in April 2019 so anything then or later should be good.
If you have your Factory Stock File on your nGuage SD card, Could You email me that Stock File?
I then could load that stock file as a custom file, as a modified file and then save it on my nGuage as my stock file, allowing me to have my own stock file. At this point, I think that is as close to getting a stock file for my truck as i'm going to get. If your stock file is before you did any modifications that would be great but if there are only minimal mods to it like those you made using FORScan, I have no problem with that.
Thank you guys for any help you can be.
Roger
email: [email protected]
If you need to get more info you can call or text me at cell: 717-512-2873 but if you call, you will probably have to leave me a message & then I will call you back. I get to many junk phone calls so I normally don't answer an unknown number.
Thank you very much!
