Oil change reminder in forscan
rekceyd
Philippines
2017 Ford Ranger Wildtrak 2.2L 4x4 AT
Has anyone tried enabling the oil change reminder in forscan? I tried enabling it on my 2017 Ford Ranger Wildtrak, but I cannot reset it.
Does the PCM have to support it?
it should already be enabled as far as I know, and you should see a (Oil Life Reset) or similar in the IPC menus, honestly its worthless in my opinion - I never have used this reminder on any vehicle.
Oil Change by - Odometer Only @ 5k intervals, perform the change then reset via the IPC menu, sometimes the vehicle will have a special procedure - key on - press accelerator pedal 3 times and then get a feedback chime.
With you having a older ROW Ranger and a Diesel, it may be different
