Oil change in 10minutes
Augie81
Looks like John's video would help him out more than we have. lol
But the guy in the video pronounces schedule like "shed you al" that can't be right. :D Okay I'm officially out of this thread. If anything I hope all this off topic talk brought more attention to the OP's issue.
seeing the rails are off....
hows those Habs doing??? GO Montreal!!!
Always been my favorite team. Only problem is this run will keep Bergevin around longer.
CB750F
Qc
Human
Go Habs Go !!!
RangerBI2019
RangerBI2019
Charlo
Malta
Ford ranger wildtrack Bi 2019
Security
I assume the Op has a Australian version with the 3.2 diesel. Everything I can find on this subject is that if you drain the oil for more than 10 minutes, the pump can lose prime. I would contact a local Ford Service department or just read your manual. Also, from what I read, in some parts of the world, doing your own servicing "can" void the warranty. I think you should make darn sure what you are getting into and understanding what you are doing when changing the oil on that engine
Thanks for your help mate? if you hear something from ford let me know? thanku again
NickTheEnforcer
Anthony
Northern Illinois
last weekend i changed mine for about 4th time. best time so far 20min to pull on ramps, take well liner out, metal tray, etc. any faster imo is sacrificing something..
RangerBI2019
RangerBI2019
Charlo
Malta
Security
Hmm thanks for you reply mate much appreciated ?
RangerBI2019
RangerBI2019
Charlo
Malta
Security
RangerBI2019
RangerBI2019
Charlo
Malta
Security
at this point, if you've done lots of research, and found nothing....thats your answer.
its not a problem with the 2.0 like it is with the 3.2
Thanks for your reply
Joeiconic
Just let the dealer change it if you’re still unsure and concerned about it.
DKDO
Anton
Moscow
Ranger 2014
yes it should be changes ASAP.
we lost couple 3.2 engines because of that.
also, you can replace your variable oil pump with fixed one, same fit.
it can be found in t4 rangers and some ford transit.
1c1q 6600 is partnumber.
RangerBI2019
RangerBI2019
Charlo
Malta
Security
Thanks for your reply, but only on the 3.2 engine?
Thanks again
