New tires - I’m in love
hughesjv
Aurora, CO
2019 Ford Ranger Lariat FX4
What tire and what brand...I can make out wild something, maybe?
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Bob902
St. Louis
RETIRED!!!!
I really like my Wildpeak AT4W tires.
Chris M
Surprise, AZ
Security Supervisor
fjwlobo
Fred
Brooklyn Park, Maryland
2020 Ranger Lariat FX4 SCREW
What Load Range did you get?
SL (46 lbs each / max 50 PSI / 2,679 lbs per tire)
XL (46 lbs each / max 50 PSI / 2,756 lbs per tire)
E (53 lbs each / max 80 PSI / 3,415 lbs per tire)
I've been looking at either the XL or E. I want a tire thats good for daily driving, but also is a good match to tow a travel trailer (GVRW 4,795 lbs).
I would like to get some opinions ? on their experiences with this tire.
Thanks ?
Thanks ?
Don't over think it. All 3 will do just fine with towing. Thinking you have to have an LT Tire in order to tow is a complete myth. You simply need a good quality tire that meets the Specifications of your Vehicle in order to tow.
RangerPNW
Thomas
Santa Fe, NM
Thanks ?
E load is overkill and will impact your ride quite a bit. I jumped from standard rated duratracs to e load ko3s, and the ko3s are very stiff. I need to air down for washboard whereas my duratracs were fine for short sections.
But if you want the most puncture resistance, then e load is the way to go
TheAssuager
TheAssuager
2020 Supercrew XLT
Thanks ?
I hope others can chime in and be more helpful, but I picked up the lowest load range. I do zero towing. The truck stuff I do is never heavy, usually just lots of junk or gear that isn't too heavy. These worked for my needs.
tk421
Josh
Gilbert, AZ
23 Ranger XLT FX4
Upgraded from stock tires to 265/70/17 Falken Wildpeaks AT4W. Night and day difference in the look of my truck.
They look great. These are the ones I have been looking at when it comes time for replacement. Do you have any suspension mods done to the truck?
Grandaccess
Binghamton, N.Y
Computer Consultant
Thanks ?
for all around use I have settled on 41 PSI 5 or 10 psi in either direction is not going to matter very much...
I off road a lot and I have never had to air-down
