New Nitto Terra Grappler G3
Alton, NH
2021 Ranger Tremor
Put new G3’s on my 21 Tremor 265 70 17 XL. Great road biased all terrains. No rock crawling around here (?) so I went lighter duty. Dead quiet except for a low tone at 70-75mph. Much quieter than my stock LT C Grabbers which were moderately loud and had cyclical hum. Nitto G3’s are By far the best balanced tires I’ve ever had )including Michelin Defenders. 3 tires required no weights to (Road Force) balance and one took a single skinny little 10 wt. Amazing Quality control if they are all this good! They never tipped over or rolled in garage before I got them mounted.
Some neat technology in these (dimple sipes, reinforced lugs, yada). I almost bought Cooper Road and Trail before I found these. Had last generation cooper’s on my 4Runner- good tires but they used to flat spot in winter which annoyed me (always worked out in first 1/2 mile though).
These G3’s in my XL size are about 5% heavier than coopers would have been and about 10% lighter than my LT C Generals. So far they Work very well in snow, although I haven’t driven them enough to tell if they are as good as the Generals in snow (Generals were awesome). They also feel like there is less rolling resistance and steer great- I expect to pick up a 0.5-1 mpg with these.
if you are interested in a more road focussed AT they are worth a look.
Dereku
Chicagoland Area
Nittos have always been my go to truck replacement. Even did mud grapplers once. No drone with those, just noise.
Simon Says
Simon
Quebec, Canada
2016 Mustang GT PP / 2022 Ranger Tremor
Peace officer
Do you have a picture with them mounted on the truck?
And how do you compare the stiffness on the road to the Grabbers in load C? Looking for a new set soon to replace the Grabbers on my Tremor too and I would like to get away from an LT, since I don't go offroad much and complaint about how stiff they are on the road.
neat1954
Tulsa,Ok.
2022 XL Supercab FX4
I just had these mounted on my 2022 FX4 last week. I stayed with the stock size (265-65-17). These look to be a great all around tire.
Alton, NH
2021 Ranger Tremor
Here ya go. We are in deep freeze now (Stowe Vt) so its constant salt and filth (snows a couple inches every day without a snow storm. Maybe we’ll get a nor’easter this weekend and get a decent dump! ?the air mass is set up for it.)
I had Michelin Defenders before and they are beautiful street tires, surprisingly good laterally in snow but no where near these G3’s laterally or in acceleration /stopping. Plus I had Defenders on two trucks and i got nails and screws in them 3 times. Probably coincidence but in my mind they are nail magnets! ? If snow and occasional off roading werent an issue I might go Continental Terrain Contact AT. Good luck , there are lots of good choices.
Alton, NH
2021 Ranger Tremor
G3’s might ride a bit softer, but not really much difference in my experience ( I put Eibachs on my truck which are slightly less supple than the Fox 2.0’s anyway). Ihad no issues with ride of the General ATX’s. The G3’s do feel to have a bit less rolling resistance on dry pavement.
Im running 33 psi which is what an on line pressure conversion calculator came up with to go from 39 psi LT C (ATX’s) to 265 75 17 XL (G3’s I bought). I havent done any chalk test as yet, But 33 psi seems reasonable.
Alton, NH
2021 Ranger Tremor
G3’s have dots on sidewall next to where the valve on wheel is supposed to go when mounting.
