Langwilliams
- First Name
- Langley
- Joined
- Dec 31, 2019
- Threads
- 24
- Messages
- 2,934
- Reaction score
- 6,640
- Location
- Lorain, Ohio
- Vehicle(s)
- 2019 Ford Ranger XLT, 2014 Harley Street Glide
- Occupation
- Mail Carrier (retired) Navy Vet
- Thread starter
- #1
If anyone is considering the Nitto Grappler G2's I figured I'd post up a quick review since I just played in the snow with them. I got them about 2.5K ago. The stock Bridgestones had a little life left in them but winter was coming an I made the change 2 or 3K early.
I went with 265/70/17's at 30 psi. They ride and handle routine commuting very well. Same noise level as the stock tires. No slipping in rain or any problems with wet roads. I probably lost .5 mpg with the bigger tires an 1.8" level.
Today there was about 2-3" of wet snow on top of driven on packed snow. I couldn't see an asphalt. I left the 4wd off for this experiment an I have no weight in the bed. The truck climbed the slight hill leaving the condo no problem an no slipping. Handled the snow covered side streets fine. I took a back road with an uphill road that stops at a more heavily travelled road. It pulled the hill find an pulled away from the uphill stop in wet sloppy snow fine with some wheel spin but but it pulled ahead at a steady rate. Took the snow covered highway home at 65 with no problem.
I'm pretty sure the stock Bridgestones would have required 4wd to climb the hill out of the condo complex an def would have been needed to pull away from the hill top stop. So if you live in a cold climate I think most people would be happy with these tires. One factor is choosing them was that the weight 40 pounds vs 50 plus for the wildpeaks and bridgestone K02's. I don't hit the trails for a hobby so the G2's handle what I want from a tire fine. If I spent a lot of time off road I might have taken the MPG hit an gone with the heavier tires.
