DirtRipper22
- Thread starter
- #1
Hey all! New member here.
Twice now my motor has stalled on me while cruising around through the desert. First time it went into limp mode after stalling 5 or 6 times, but would start back up, with a couple of long cranks to get it going. Kept the rpms up and drove it 75 miles back home. Check engine light was on.
Codes present:
P008A - Low pressure fuel system pressure - too low
P00C6 - Fuel rail pressure too low - engine cranking bank 1
P0217 - Engine coolant over temperature condition
Its a 2022 Ford Ranger Tremor, the battery lasted me 4 years which is unheard of here in AZ. So I thought that may be a good place to start. In case it was sending low voltage to sensors. Swapped in a new battery. Reset codes. Took it out for another desert trip the following week.
Got another stall with the motor. This time it happened when I nearly got stuck in mud, revved the motor up and got that turbo cranking to get me out of the hairy situation. Threw the truck in park to check my lane, and she stalled out on me again. Started right back up.
Truck seems to lack power going up hill climbs just for brief moments. I watch the rpms drop down a bit.
This time it did not throw a check engine light and go into limp mode. And now only one of the 3 codes from before is present:
Could this be a weak or failing fuel pump issue? I've made a terrible habit of running the tank close to empty everytime before I fill it back up.
Or could this be a faulty fuel low pressure sensor?
Codes present:
