Misaligned tail lights
JalanX
J
Alexandria
2021 Ford Ranger Tremor XLT
Project manager
Darn landscape comp mower hit a rock and chipped paint on my tailgate. When I dropped it off at auto body shop I took some pics and noticed how off the lights were from each other. Passenger is tight on the bumper which may not be great for flex. I also just noticed that the driver side has a rock chip at bottom. Guess that will need fixed too. The tops of the lights follow the same way, as one gap is more than the other.
mailbox4449
Illinois
Not sure yet
Usually the holes in the bed/body panels are just a hint larger than the screw/peg that goes into those holes. So there is usually a bit of play (1/16"-1/8"). It really is just a matter of loosening the nuts a bit and shift the lights to the desired position and tighten the nuts down. That being said, if the bed/body is not aligned or the holes were drilled off by the factory, then it will be off when installing the lights. Body shop should be able to adjust those for you especially if they worked on it. :like:
Hi Alex,
Just for clarification, most factory holes are punched....not drilled...
mailbox4449
Illinois
Not sure yet
Hi Alex,
I know, but I have found that when mentioning "punched holes" to the average person, they look at you funny and need clarification, so I just always have stated "drilled". But yes, punched out they are ;)
JalanX
JalanX
J
Alexandria
Project manager
Thanks all. I will try to adjust them once they fix the rock chips in the tailgate.
JalanX
JalanX
J
Alexandria
Project manager
Update. I did loosen the 2 screws to adjust the light and the machined holes are big with lots of play. But I could not move the light up. I mean maybe I got it a hair higher. But the worst is once I could wiggle the light I noticed it has worn off the paint the bumper in the area. So I guess you should check yours. I imagine I will have to tell dealer & they will fix the paint.
HTX1811
HC
Houston, TX
19 Ranger STX 4x4,16 Audi A7
Or be like me and say it's a Ford truck. Meh. I am not worried about the little things. So it's easy for me to give it a oh well and drive on.
JalanX
JalanX
J
Alexandria
Project manager
Unfortunately I live in an area that heavily salts the roads and that is a steel area that’s chipped. So I have to get it taken care of.
HTX1811
HC
Houston, TX
Makes sense. In HTX we don't worry about that but my beach trips could take a toll due to the salt air and salt water I tend to get on the truck from time to time.
JalanX
JalanX
J
Alexandria
Project manager
Dropped the truck off to have both tail lights re aligned and fix chipped paint from each light rubbing. Passenger taillight rubbing paint at bottom, driver taillight rubbing paint off at top. They said paint shop is down road from dealer & paint shop will be reinstalling lights. We will see how it goes. Some others on Facebook had same issue. May want to check out your tail lights.
JalanX
JalanX
J
Alexandria
Project manager
Well I got a call from the dealership saying that their body shop says there is no room to adjust the lights. So if they fix the paint the same thing will happen. They are sending everything to corporate recommending an entire bed replacement. On a brand new truck. Not what I want to hear. Plus I had it line X’d and lots of bed ad ons. Not sure what will happen or how this will all work but not a very happy ford customer right now.
Also they said they had 2 other rangers on the lot and they went outside to look and they have the same issue??
JalanX
JalanX
J
Alexandria
Project manager
Hopefully corporate comes up with another idea besides total bed replacement.
JalanX
JalanX
J
Alexandria
Project manager
I guess I can give them some points for not just fixing the paint and putting the lights right back in but there has to be options. I would rather fix the paint and shave down the plastic a little in the area the touches or maybe a tiny bit of body work. Plus both rangers on their lot have same issue when they looked. Are they going to replace both those beds too or just sell the trucks and not say anything. Will be interesting to see what corporate says. Hard to see them approving a total bed replacement. And it will be a year before it even comes in I’d imagine.
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
My pass-side taillight sat lower from the factory, in my attempts to fix I had bend the upper fastener mount tab upward and use quite a bit of upward pressure whilst I tightened the fasteners.
