peterson1604
- First Name
- Scott
- Joined
- May 31, 2020
- Threads
- 34
- Messages
- 528
- Reaction score
- 2,153
- Location
- Escanaba, MI
- Vehicle(s)
- 2019 Ranger XLT FX4
- Occupation
- Body shop manager
- Vehicle Showcase
- 1
- Thread starter
- #16
I'd like to do this tonight but the parts store doesn't have any shims in stock, go figure. Do you have the Amazon link on the shims you ordered as well as the bolts? I'd like to order them. Also, while a bit more work because you have to fully remove the bolts and support the driveshaft, could you just use washers instead of shims?I just ordered a set of cheap alignment shims off Amazon and started with a 1/8 shim on each side of the bearing and then increased it by 1/64" until it stopped vibrating at 5/16". I also swapped out the stock bolts for longer stainless grade 8 bolts and lock washers to compensate for the shims and to prevent the bolts from rusting or backing out.
Thanks,
Scott
