Loud screeching brake noise?
CP0861
C
Maryland
2022 Ranger Lariat Supercrew
Last night, I drove a short distance to go fishing. Fished for 20ish minutes, no fish, got back in my truck to leave and the front passenger wheel was screaming like a liberal at the sight of a Tesla.
It was metal on metal....loud screeching like a brake pad worn down to metal on the rotor. I checked 4wd....emergency brake...nothing engaged or out of the ordinary.
63K miles....have never heard or experienced that before.
Took it to dealer this morning, it squealed slightly as I backed up, and then the sound was gone moving forward and driving to the dealer. Of course they found nothing. Brake pads were at 8mm up front and 5ish in the back (they've been squeaking a lot lately also). Rotors looked fine....took tires off to rotate and inspect, and they found nothing. The tech seemed very thorough and came out 2 or 3 times to ask me questions.
What's the deal? Why the one time occurrence?
Did you drive on any roads or paths with small gravel?
It sounds like a piece of debris (Rock) got wedged in between the backing plate and the rotor. - and when you backed up it fell out.
k1w1t1m
Tim
Bull Shoals, AR
2021 Ford Ranger XLT FX4 SCREW
A small rock will make a lot of noise if it get stuck between the rotor and the back plate. That sounds the most likely reason for the noise.
One more vote for a rock getting lodged somewhere it didn't belong. I actually had this happen once and backing up dislodged the rock and the noise was gone.
CP0861
C
Maryland
Gotcha. Small rock makes sense. I did back up and pull forward about 10 different times when it first happened. Musta been super stuck. First time for everything I guess.....
OGMix376
Bryan
Another vote for the debris.. happened to me before. Glad you didn’t get any damage from that annoyance.
