Lift height measurement help
fORdEGON
Ryan
Grants Pass, Oregon
2020 Ford Ranger SuperCab Lariat FX4
Excavation Contractor
Does anyone by chance have measurements from center of hub to bottom of fender on a stock height FX4 front and rear? I was in a rush when installing my OME leaf springs and Fox 2.5s and didn't get any pre lift measurements. I'm trying to establish how much lift I ended up with as the rear is riding VERY high with the new leaf packs (OME 4+1 rated for 600lb constant load). Thanks
Mighty Little Blue
Wisconsin Rapids, WI / Philippines
2021 Velocity Blue Supercab FX4
Printer/Retired
I think these measurements are real close to what a stock 2021 Lariat with FX4 package starts with.
It was late and dark when I took the measurements.
If they are way off I have 2 other sets of measurements I measured in 3 different places for each.
PF 21.75"
PR 23.875"
DF 21.5625""
DR 23.25"
Hi Ryan,
My stock 2019 FX4 Crewcab, unladen with Bak Revolver toneau. No passengers or driver. Static in a dead level garage.
Front: 21"
Rear: 23 7/16"
best,
So the standard leaf will lift the rear by 1.4 inches after setteling down. The medium springs(what you have) will be at the same height with a constant load of 600 lbs. Without load it will be higher.
I myself ran the standard leaf in the rear along witht the complete standard nitro Charger kit from Old Man EMU. I did not have any issues with it.
See pictures below for reference with both 32 and 33 inch tires
