Leveling kit problems
P-38Ranger
San Diego
2022 Ranger Lariat
Lift / Level with bigger tires are a must have for many putting the personal touch on their rig...even if it is just for aesthetic reasons....
I fully understand the need to do that with a 4 x 4
nolan62
Ed
Loganville, GA
2020 Ranger
IT Engineer
You need a better shop. I have a 2020 with the RC 2.5" leveling kit. I let my dealer install it and it rides and drives even better than stock. By the way, they have a Quick Lane next door with brand new equipment that did my alignment. Later I put on new wheels and tires. Absolutely love the ride and drive now.
Eric
Southern Maryland
2021 Ford Ranger STX
Supervisor
RC provides alignment numbers specific to the leveling kit. You can go to their website to download it if you can't find it. Makes sure your alignment is according to there specs, not the Ford specs.
Bishop
Craig
2021 Ford Ranger XLT
Shop Foreman
Can you post a pic of the passenger rear cam bolt? You do have a little more negative camber left in the front cam bolt, but not half a degree.If there is more adjustment on that rear cam we could get more negative camber but in turn gives us more caster. So long as the Driver rear cam bolt can do the same, then we could even up the caster side to side and keep our camber numbers good. Caster will not effect tire wear, only handling. If anything, you want more caster with a lifted vehicle. caster can cause a pull if it is not even or alittle less on the driver side (to compensate for the crown of the road)
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
I have a 4x2 Lariat and I hate the rake also, then I just get in and drive it.
I went to a lot of work back in the 70s to make my 69 Roadrunner look like a cat in heat with the rear jacked way up, and if anyone thinks I am going to spend a bunch of money to do away with it on my Ranger are crazy.????
