Lane Assist Issue
Ranger X
Bruce
Marion, SC
2020 Iconic Silver Ranger Sport 4x4
Retired Fire Marshal
Has anyone had problems with selecting the Aid & Assist option in the information center. I have to keep selecting it every time I drive the vehicle, it won’t default to the previous selection
Hi Bruce,
Been a while for me but I thought it was Warn and Assist. I chose Warn only as I do not want the truck assisting me on lane keeping.
best,
Ranger X
Ranger X
Bruce
Marion, SC
Yes sir you are correct, warn and assist... I just wish I didn’t have to go into the lane keeping section every time I start the truck, seems a little redundant
maybe I’m missing something here?
Out of curiosity, are you on the latest version of software? Did you do a system reset? These settings should take to what ever you set them at and remain that way. Not sure if you’re selecting these changes while system is active or switched off from the turn signal switch. In mine I make adjustments while it is off. Then switch it on and they’re good. Hope that helps
Ranger X
Ranger X
Bruce
Marion, SC
Tried selecting while in the “off” position like you said to no avail. Purchased new two weeks ago. Will check software next. Thanks
Cape Cruiser
Bret
Southern Delaware
retired mechanic
Bruce, I think you need to hit the end of the turn signal switch which will turn it off if you want it off. Bret
Ranger X
Ranger X
Bruce
Marion, SC
are you using a key set up to the My Key functions?
Yes I am using the my key function and I discovered that when I disable
yes I am using the my key function and I discovered that when I disable the my key the lane keeping mode stays as I have selected “alert and assist”
thank you all for your input!
