ch47dmechanic
- First Name
- Jason
- Joined
- Sep 5, 2019
- Threads
- 3
- Messages
- 498
- Reaction score
- 806
- Location
- SF Bay Area
- Vehicle(s)
- 2019 Ford Ranger XLT Sport 4X4
Some modern diesel engines still have this problem. For example, MTU (think very large 1500+ HP engines) still requires a pre-lube procedure to be completed after any oil change and furthermore, the oil filters are installed in a downward sloping angle so the oil runs out of them when the engine is off. This is especially a concern for generator setups that sit without running for long periods of time. In fact, MTU’s own engineering team states that if the engine isn’t started and ran at least every 30 days, the main bearings will likely fail when and if the engine starts on its own due to a grid power loss. In fact, we had an engine powering a 2 megawatt generator end with less than two hours of run time do this at a hospital. Blew a hole right in the side of the block when it threw the rod. That’s a $1.5 million dollar mistake.
