Instrument cluster swap
y2krtaf
Gary
USA
2020 Ranger
Aircraft mechanic
Looking for information as to how to do a cluster swap in my XL.
Picked up a cluster from an XL,but waiting for mine to gather a few more miles.Mine has 2400 on it and the cluster I picked up has 2600 on it.
Looking for cluster removal,what has to be taken apart physically,and then if some one has been there done that,what changes in Forscan,ie,where are the changes made etc.
Thanks in advance for the knowledge.
y2krtaf
y2krtaf
Gary
USA
2020 Ranger
Aircraft mechanic
Hello
y2krtaf
y2krtaf
Gary
USA
2020 Ranger
Aircraft mechanic
Thank you,any other tips or insight,was kinda hoping to have a separate thread for others looking to swap.
I get tired of my little screen blanking out here in the Arizona heat.
Ford thus far,refuses to acknowledge the issue...
JaysOnTheEDGE
Jay
Office Equipment Technician
look at the PDF and it gives you a general location of where the fasteners are to pop them loose, I just used a plastic trim removal tool. The vinyl black cloth is attached the outer trim panel so you'll have to undo it from the top of the steering column as well be careful not to rip the vinyl, think the screws were 7 or 8 mm heads. A couple of the lower screws you'll need a short driver or a swivel socket would work too. don't drop the screws
I didn't change my cluster just removed and re-installed same unit so i can't help you with that aspect.
y2krtaf
y2krtaf
Gary
USA
2020 Ranger
Aircraft mechanic
Perfect,and thank you. Little tips and tricks like that make all the difference!
I dont know much on the programming part but in ForScan you can input differnt miles if needed.
y2krtaf
y2krtaf
Gary
USA
2020 Ranger
Aircraft mechanic
theanswer3
Tampa, FL
2020 Ranger XL
I switched to a lariat unit form the tiny XL one. It is pretty cut and dry. like 7 screws it comes out, un plug old one, plug in new one. load forscan with your asbuilt data, then it works like a charm. it will work without forscan, but if the one you got has features or options your truck does not have, it will cause warnings.
y2krtaf
y2krtaf
Gary
USA
2020 Ranger
Aircraft mechanic
‘What I neede to hear,the changes that need to be made are in what area fo forscan,bcm,or?
y2krtaf
y2krtaf
Gary
USA
2020 Ranger
Aircraft mechanic
Did the cluster swap today,very straight forward.
From the standard XL one that would blank out in the heat....
To one from an XLT
y2krtaf
y2krtaf
Gary
USA
2020 Ranger
Aircraft mechanic
Got it sorted,made 3 changes in IPC module configuration ,and no more lights or warnings.
Also added the TCM control knob to my truck,so now I have those cool features!
