Injectors
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
My12SecRanger
Patrick
Las Vegas
21 XLT Ranger 2wd
Ford Tech
I used a methanol kit for extra fueling on my Fusion with no issues
Loweredon33s
Loweredon33s
Baltimore
2021 Ranger
Performance person
I don’t want to do that, I want everything on one controller with no outside fueling.
My12SecRanger
Patrick
Las Vegas
21 XLT Ranger 2wd
Ford Tech
I can understand that I am very curious how this turns out and will be watching this thread
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
The all have 4 lobe cams, the HPFPs have different part numbers but I don’t know what they flow. I know I’m running over 3000psi and not losing pressure yet but my injectors are done. I’m sure I’ll need a pump once I get injectors but I’m doing one thing at a time to be thorough.
Is the Fuel Rail Pressure the same as the psi reading you are seeing on your injectors. For kicks, I was watching my FRP on my iDash and at idle during startup it was hovering around 3600psi.
Loweredon33s
Loweredon33s
Baltimore
2021 Ranger
Performance person
Not sure I understand what you’re asking between rail pressure and injector pressure, they use the same sensor. My pressure is currently fine, the injectors just don’t flow anymore. I’m going to get a set of + 50% Ranger injectors from XDI as soon I possible so we can finish tuning. If it ends up needing a pump I’ll do that next.
DROZ23
Dan
VIRGINIA
2022 Ranger Tremor
Beening Badass
I'm not too sure of the exact strength of the 2.3, but if you are putting that much too the wheels I can promise you that you are doing just fine and should probably stop adding power for reliability reasons. From stock that is already a HUGE Gain in Performance
I have read a few times on some tunning pages that the 2.3l EB turbo can run around 420HP reliably. So he is getting close. I also hunt for the 400 HP mark. I am over building much of the other components so It is has the best chance of staying reliable.
Loweredon33s
Loweredon33s
Baltimore
2021 Ranger
Performance person
My truck is riding in the neighborhood of 370rwhp right now, I plan on seeing 400 but I’m not trying to pop this engine so we’re not gonna force anything for a number.
DROZ23
Dan
VIRGINIA
2022 Ranger Tremor
Beening Badass
You either get there with solid fundamentals or your run that risk.
Loweredon33s
Loweredon33s
Baltimore
2021 Ranger
Performance person
We are doing every part in steps, developing tunes as we go along. We’re scientists man.
