I might do this upgrade
dkirby
USA
'22 Lariat Tremor, '16 Focus RS, '10 Evo X
@lawrench I got this response from Redtek Sunday evening, but nothing since.
Thank you for your email and extremely sorry to hear about the backward window function. I will pass your message onto Kyran (tech) to see if this can be rectified on your end or whether we need to send you another LHD loom ASAP.
Kind regards,
Sarah Orton
REDtek
Meanwhile I got this from an electrical engineer co-worker. If I don't hear anything else in the next day or two, I'll take matters into my own hands by swapping the corresponding pins in the Redtek harness.
lawrench
lawrench
Harry
2019 Ford Ranger Lariat SCrew FX4 Lightning Blue
That looks like a handy wire diagram, I would keep that handy.
HTX1811
HC
Houston, TX
19 Ranger STX 4x4,16 Audi A7
Installed today. Super easy and works as advertised.
Only one issue that JB Weld should fix. Top clip on the handle cover would not unass its clip so it broke.
Best bang for the buck mode yet. Well right after the key bezel ring thing. Lol
gwhalin
Greg
New York
Broke mine as well. I just stick it back in there and closed everything up. :)
HTX1811
HC
Houston, TX
I used JB Weld epoxy and let the piece cure in place. Then I filled the whole inner area with more epoxy by standing the cover on its end so the epoxy would not run out while curing.
I’m certain it won’t break in the same area again.
Certainly overkill but it’s fixed. Lol
dkirby
USA
Update to my backwards driver's window controls. Redtek's tech guy emailed me asking if I wanted a new harness. I said yes, but decided to attempt to fix it myself anyway. I swapped the two wires on their harness that correspond to Ford's blue/grey and yellow/violet. It worked like a charm. I also learned that they have to rework the harness for us LHD Yankees. That's probably where it got messed up. So I'm all good now.
EDIT: Maybe I spoke too soon. I noticed the window lock feature on the driver's door doesn't work. The rear door window switches still function regardless of the window lock status. It's no big deal, but can anyone check their operation for me? TIA.
HTX1811
HC
Houston, TX
I have not tried the window lock feature. I will see if mine works. Glad it is working otherwise.
AZ_Tremor
Angelito
Cave Creek AZ
2022 Ford Ranger XLT Tremor
Field engineer
Just ordered mine today… it said back ordered but it let me pay and order? I’ll keep everyone posted on how long it takes..
