Hey guys, would a tune installed help with my rough transmission shifts.
Extreme01
Glen
Maryland
2020 Ford Ranger XLT FX4, 2008 Shelby GT500
I've taking it to the dealer and was told it was normal. Something is just not right. I can feel vibrations in the floorboard under the gas pedal. I'm getting some hesitations through acceleration and hard shifts. Anybody else dealing with these issues, and if so how did you rectify it. Thanks, Glen
CO2Ranger
How many miles on the truck? I would try a different dealer and see where you get.
If it's truly a concern, adding a tune is only going to complicate warranty support.
Extreme01
Extreme01
Glen
Maryland
2300 miles
Extreme01
Extreme01
Glen
Maryland
If I get the ford performance tune and have the dealer install it the warranty wouldn't be voided.
CO2Ranger
True, but if it doesn't solve the problem you've now spent money and are right back where you started and with a shorter powertrain warranty...
Extreme01
Extreme01
Glen
Maryland
So I'm the only one here dealing with this issue?
pull string get cookies
Justin
Minnesota
2019 Ford Ranger Lariat FX4 White Platinum
I recommend requesting a ride along with someone from the service department at your dealership. That way you can point out your concerns, and they may be able to better discern the issue/s. If your dealer is not amiable to that, I’d suggest finding a different dealer. Good luck
Crown Forklift Technician
I will agree that a tune can help but be aware that even with the tune it does take up to 3,000 miles to smooth out. I have the tow tune from Livernois and it is awesome!! I just did two loads with a trailer as well yesterday and it did just fine.
StezenW
Stephen
Atlanta
Hey Glen - definitely would get your issues sorted before looking to a tune. These 1080R transmissions all go through a "learning" process when new to optimize shifts based on your driving styles. It sounds like the potential issue here is that yours is not "learning" the way it should be, as typically this process only takes 1000 miles max. During this "learning" process it is not unusual to have rough shifts that are sometime made more noticeable by light throttle input and sudden acceleration.
While it is true that the Ford Perf tune along with many others does optimize the shift scheduling, it may not rectify an existing issue.
What I would suggest is along with the ridealong with a technician suggested above is have the dealer reflash/ reset the transmission, as doing so should in theory set the transmission back into "learn mode".
You definitely want zero kinks in your truck's performance before tuning.
Best of luck!
Extreme01
Extreme01
Glen
Maryland
Best of luck!
Much appreciated
GhostStrykre
Bowen
Ohio
2019 Ford Ranger XLT FX4
Best of luck!
any clue if this also applies to a new driver? i bought a use 2019 ranger and while it's by and large great, the shifts/transmission can act peculiar at times. wasn't sure if it'd ever smooth out. i don't have any hesitation or stutter, but the shifts are sometimes smooth, sometimes harsher. it just goes back and forth.
Extreme01
Extreme01
Glen
Maryland
Much appreciated bud. Truck just turned 2500 miles and is shifting so much better, so I'm assuming its learned my driving style
Unfortunately that is the general nature of the 10 speed in these trucks. When I installed the performance tune and tow tune in MT truck the transmission had to relearn itself and me. Some days i hardly feel the transmission, other days I feel it. I think it really comes down to if i let it warm up first and how hard i get on it. After a few thousand miles(yes it took that long even when i bought it new) the transmission was as soft as it was going to get.
slowmachine
New Hampshire
If you’re a conservative driver, the transmission shifts to keep the engine RPM very low, sometimes below 1500, and I notice quite a bit of vibration (almost lugging) at low RPM. This is great for fuel economy, but I find it annoying. I can smooth it out immediately by enabling Tow/Haul mode, which increases RPM. Sport Mode will do the same but revs much higher in each gear than in Tow/Haul.
I wouldn't quite say that it is lugging the engine but more of the natural harmonics of a 4 cylinder. Still annoying but I'm pretty sure it come down to the nature of things.
