Height
Georgie
George
Ormond Beach
Toyota 4Runner
Does anyone know the height of a 2020 Ranger Lariat to the tip of the antenna?
Hi George,
4x2 or 4x4? I can measure mine if you like the 4x4 Lariat with original antenna, (not the Cravenspeed stubby).
Georgie
George
Ormond Beach
Toyota 4Runner
I would be for a 4x2 that i plan on purchasing.....Thanks
Hi George,
Okay.....My Lariat 4x4 height to the tip of the antenna is 80.25". 4x2 should be less, but by how much IDK.
Ranger Vehicle Engineeering
Ace Holliday
Scott K
South Kalifornikstan
2019 Ranger XLT Super Crew
I was under the impression that the 4x4 and 4x2 use the same suspension components. That would equate to both being the same height. Assuming the tires are stock. Of course I could be mistaken.
Augie81
If you are concerned about height for your garage... My 2019 FX4 fits no problem. And that was when I had the factory antenna. My garage door height is 81 inches from the lowest part of the the door when opened to the floor. So any unmodified Ranger you buy should fit as long as you have at least 81 inches of clearance for your garage door.
If you think you need a few more inches you can get the stubby antenna from CravenSpeed or just remove it if you don't care about AM/FM. In that case you might want to find something to plug the hole. I went with the 2 inch stubby because I didn't like the factory antenna and used it to plug the hole.
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
The 4X4 sits 1/2 inch taller than the 4x2.
