Grille Removal?
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
When I replaced my grill and changed to the RTR grill, I squeezed the clips together, so to speak and slowly pulled out on each one till they all released.
Bsthroop
Brian
New Mexico
2019 Lariat 4x2 Sport
Broadband/ Microwave Engineer
Here are a few photos of the clips
emesel
New England
Thanks! This is helpful. Now I just have to figure out how to get something in there to depress the tab ...
Bsthroop
Brian
New Mexico
Did you use a tool to get to the clips. or did you fit your hand in there somehow?
It's been a while but I think it was both. A few you can reach and others you can push with a long screwdriver or similar. It's important to locate them all because they are hard to see. The clip needs to be pushed outwards. 5 clips on the bottom and one on each end. I did break one before I figured it out.
I haven't had to or tried to remove my grill, but reading along it seems that the "clips" need to be pushed down to release. If this is correct, than couldn't you simply use a piece of dowel rod long enough to reach to push down on the clips ???
QuickSilver
Daven
Vancouver Canada
2020 Ford Ranger Lariat
Ya I fought with my grill, it can be tricky. Mainly it’s pressing down in the middle of the clip, after that it’s patience.
06Warrior
SW Florida
2020 Ford Ranger XLT
Staying busy
I have taken mine out before. There are several videos on YouTube. Here is just one.
emesel
New England
Thanks! I ended up removing the plastic around the hood latch and the plastic baffle/piece above the clips. Then I finally got them released. The middle one was the most difficult to do without looking a hole in anything. Many thanks! Mark
ControlNode
Eastern NC
Computers
When you reinstall the grill, reinstall that center divider and latch cover before you push the grill back in, makes the reinstall much easier.
emesel
New England
Yes, I did. I watched a YouTube video where the guy did not do that, but it seemed like it made sense to.
Thanks, Mark
theprinceofsnj
Richard
Clayton NJ
2019 Ford RangerXL 1959 Edsel Villager 9 passenger
I've got the only one in my area. And it's an insert.
