Fog light adjustment?
apotocki
Alan
Rochester Hills, Michigan
2019 Ranger XLT
Network Force Analyst
Sorry if this exists somewhere but I tried searching and came up empty.
I recently installed new bulbs for my fogs. I noticed that my passenger side is aimed really low - much lower than the drivers side.
Is there an adjustment to raise and lower the fogs? If so, please provide more detail. Thought I’d ask before getting back under and removing the splash shield! Thanks! Much appreciated.
apotocki
apotocki
Alan
2019 Ranger XLT
I'm unfamiliar if there is an adjustment.
But i would make sure the bulb is installed correctly first.
They are installed correctly. The truck is relatively new and I can’t confirm if the original bulbs were this way or not. If there is no adjustment I’ll probably install the old ones and see if theybare the same way. Thanks.
dguffin
Dana
Aberdeen, SD
20 Corsair, 19 Ranger, 12 Boss, 08 Zuma
Shop Foreman
There is a wheel you turn on the back of each fog light for adjustment.
Rviator
FLA
retired aerospace engineer
Yes the adjuster wheel looks like a small gear. Crawl under the truck and look up. Mine were aimed too low.
apotocki
apotocki
Alan
2019 Ranger XLT
Easy! Just pulled the skid plate and reached up. They must have been miss adjusted from the start. I got the truck in mid December and never paid attention to them until changing the bulbs. The passenger side was a good 2 inches lower than the drivers side and both were pretty low. That’s interesting as I did a 2 inch level about a month ago so you would think they would have been high.
