FloodFord ESP plan and AC coverage
Waxthis
Eric
2020 Ranger XLT FX4
Controls Tech
Anyone know if the Ford ESP premium care plans covers the blend door actuator issues? This is from the brochure, I would assume it's covered under "registers and air ducts", but then again we know whet we get by assuming!
Air Conditioning & Heating*
  • A/C clutch
  • A/C accumulator
  • A/C clutch bearings
  • A/C compressor
  • A/C compressor head
  • A/C compressor seals
  • A/C compressor/clutch switch
  • Automatic temperature control
  • Condenser
  • Evaporator
  • Field coil
  • Heater blower motor
  • Heater control cables
  • Heater core assembly
  • Instrument panel registers and air ducts
  • Pulley
Best rhing you can do is get the factory part number and call Ford ESP. They will tell you if that is covered
Glocker
Boca Raton
If I remember correctly, it's built into the heat core assembly.
ETA: One can also articulate that it's a part of the automatic temperature control.
