Filled up with E85
Wazza1726
Warren
Louisville, KY
Construction PM
Well I’m traveling through Nebraska and just put 17 gallons of e85 in on accident. What now!?
E85=Bad for the 2.3. Might try to drain/siphon as much as you can out and refill with premium 91/93 octane.
Only the "other world" Rangers with the 3.0 are able to use the E85....their flex-fuel engines.
Figarou
https://www.allstate.com/resources/...car isn't,with regular gasoline several times.
If your car isn't a flex-fuel vehicle and you mistakenly add E85 to your tank, you may notice reduced performance and gas mileage. Your check engine light may also appear, but the mishap likely won't damage the engine. They recommend topping the tank off with regular gasoline several times. When all the E85 has cycled through the engine, the check engine light should turn off.
Tom_C
Tom
Virginia, USA
System Admin, Retired
Yeah, like Figarou posted, top up and use premium.
BassRanger
Al
Oklahoma
2020 Ranger Supercab STX, 2010 Mustang
Goodyear
Just stay out of heavy throttle. E85 isn't going to hurt anything unless you run out of fuel system capability, which isn't likely unless you are ragging on it. I'd run about 1/2 of a tank out and see if you can find some Ethanol free.
Motorpsychology
Prescott, WI
Vagabond
I would pump as much as you can out of it and then fill it with E-0.
The catalytic converter and other stuff could be damaged by prolonged running on E85, and possibly void the warranty
bRaptor
Ward
USA
2021 Ranger XLT tremor
Premium baby!!! No ethanol. I had a boss do the same thing in Germany with diesel for a quarter tank. Put the highest octane in it and run it out. I would also do an oil change sooner than you planned.
BassRanger
Al
Oklahoma
Goodyear
Check engine light is more than likely upstream O2 bank stuck lean. The ECU is having to add fuel to reach the lower stoich point of E85. I believe it will clear itself within a few drive cycles after your fuel mixture falls back into range of what the ECU deems acceptable.
RangerFitz
Alex
2020 fx2
Danger
Just drive it very easy and top it off with regular frequently. It will be fine I did the same. The check engine light will stop tripping once you get the mix below an e50 ratio.
Langwilliams
Langley
Lorain, Ohio
Agreed drive it easy if possible an top it off. If you have access to "boat gas" it's ethanal free. We have a few places around here that sell it. Premium is not necessarily ethanol free, it isn't where I live. The only ethanal free is the stuff advertised as ethanal free an it's 90 octane at the few places that sell it. This is what I buy for my small engines that don't get frequent use.
