Engine-bay fuse taps - what to tap?
k1w1t1m
Tim
Bull Shoals, AR
2021 Ford Ranger XLT FX4 SCREW
FYI - Fuse #24 is NOT a available slot for ALL, some such as my Ranger, fuse #24 is an EMPTY slot and no contacts at all in that spot, I do not know what the specifics are (Year-Trim-Etc) on if you actually have a source to tap.
adv_ranger
Nico
Seattle, WA
2020 Ford Ranger XLT FX4
Medical Student
Fun fact, you can fuse tap an unslotted fuse port as longer as there is a metal contact in that port for you to put your tap into. You just run a single surge fuse on the tap, and do not need to add an original port fuse. I will have to take a look at my fuse box and see if I have one there or not!
True, but both of my slots on my 2022, are just (Plastic) no pin contacts at all on either slot. I think some Rangers are set up for (one) side of the fuse is internally wired but there is not a pin on the other side. (so, no output wire) feeding over to the C1035 connector.
Since this is a (UNUSED) fuse location, somewhere Ford wanted to save (PENNIES) and removed the internal contact for the main power feed.
I am going to say, if you have a physical fuse in spot #24 then you have (one side) powered, if it is empty (it's completely) dead.
This may be a (Unseen) & (Unknown) Covid - If is not needed why make the PCB with power for it.
adv_ranger
Nico
Seattle, WA
Medical Student
Just checked and I do have fuse #24, so I plan on tapping it tomorrow! Sorry that yours does not have a line in on power. I think fuse #22 would be my next option if I didn't have #24
gannbino2001
chris
Nevada
2022 Ranger XLT
It is this one... It is hot when the key is on. I moved my radio feed to the inside fuse box but that one worked well.
I really would like a power feed that is hot when the radio is hot.
What fuse did you use in the inside fuse box?
