E rated
RussB
Russell
Laurens
2011 f 150
Has any one put 275/70/17 e rated tires on there trucks? And how did it ride?
Can't really say much except that they should ride just fine. If anything you do het more side wall which means more comfort but it does get a little stiffer bing an LT tire vs a P rated tire.
Hope this helps.
THLONE
Thom
Tucson,AZ
internet wise guy
It will ride rougher. E rated tires are for 3/4 -1ton trucks. Look at the load rating for tires they have a different system now days.
cb4017
Northern Nevada
2023 F150 Rattler
Retired USN and retired LEO
I've put E rated tires on lighter vehicles in the past. They can ride a little stiff but are not bad if you keep the tire pressure reasonable. Don't need 85 psi on a Ranger (or Jeep Wrangler)
The good thing is they hold up better off road. I've never killed one with a rock. I have managed to kill several P rated tires.
Probably the biggest down side for me is tire weight. They can weigh up to 10 pounds more than an equivalent P rated tire.
Not sure what I'll put on my Ranger yet. Maybe load range C or "Extra Load" tires.
Toytec
Central NC
Mine came with the Dueler A/T's and when they were removed I compared the sidewall structure of my new Falken's to the OE tires. Night and day difference. And I have P rated. I recommend those.
Ride good, less mass weight in rotation.
