Does the Tremor have Package Specific Lower and Upper Control Arms?
Aonarch
Alec
North GA/ Montana
I promise I've searched for this one, so forgive me if it's been covered.
I just picked up a '21 Tremor, and was curious if it has specific upper control arms or lower control arms, versus a non-Tremor Ranger.
I know the knuckles are "different," but what does that mean? Are they different in dimensions, or are the same dimension but made out of a different metal?
halligan1201
Byron, IL
2020 Ranger
Emergency Management
I've been trying to riddle this out for a while. Press material Ford released says it has a different "knuckle" but nobody has been able to find that the Tremor uses a different part number for the control arms.
ICE 27
H
Illinois
2021 ranger tremor
The knuckle curves out by ball joint. This was designed to fit the wider tire tremors have. This was the info I was given by ford rep. I need to pull tire and confirm. Upper lower A arms the same.
Aonarch
Alec
North GA/ Montana
Perfect, so safe to say any Ranger UCA will fit.
ICE 27
H
Illinois
2021 ranger tremor
That is what my dealership has said and the rep. I dont always take that as gospel. I reached out to camburg and total chaos and both just said you need cast iron taper uniball. Fox and king both say there shocks will work on the tremor with its uca and lower. Now instead of 2.5 to 3 inches of lift its 1 to 1.5 inches of lift. Plus both Camburg and total chaos uca will work. I've got a fox 2.5 reservoir racing shocks I'm going to put on with camburg uca when the weather changes. I will post it on here.
I hope that helps but it never hurts to reach out to the company your going to go with.
Aonarch
Alec
North GA/ Montana
Awesome thanks.
That is exactly what I want to do as well. Let me know how it goes!
Espo78
Gainesville FL
2020 Ranger STX FX4
But the tremor comes with a tire size that is known to fit on a regular Ranger without any clearance issues. To my eyes however the Tremor sits "differently" than a leveled Ranger on 265/70/17's and I think its because of a slightly wider stance.
Aonarch
Alec
North GA/ Montana
My question is, is the width purely from the different wheel specs and tires, or do the suspension components ( knuckles) make it wider.
bfastr
Nashville
2021 Ranger Lariat
well the Tremor wheels do have a different offset than the Lariat rims mine came with and stick out about an inch farther. I measured both and wrote it someplace, but if you search I am pretty sure the offsets are listed here someplace.
here are tremor wheels and tires on my FX4 package with the Ford/Fox 2.0 shocks front and back
TeaWrecks
Vincent
Canada
2021 Ranger Tremor XLT
The wheel is wider, but the offset is identical from what I've read. This makes the wheel stick out slightly more both inside and outside.
ICE 27
H
Illinois
2021 ranger tremor
Hopes this helps some. The Australian counterpart to the tremor. One of us needs to pull off tire and look for a lock stop and jounce bump stops . I have not noticed either. If anyone has info that proves this I'm very interested.
ICE 27
H
Illinois
2021 ranger tremor
This a pic of Australian front suspension. I dont believe ours have this
bfastr
Nashville
2021 Ranger Lariat
respectfuly disagree, I have both wheels and there is a measurable offset difference
ICE 27
H
Illinois
2021 ranger tremor
The wheels both are +55. The tremor is .5 inches wider. That's the difference. I thought same as you before I read it. If these are you 18 " wheels? Tremmor is last pic.
bfastr
Nashville
2021 Ranger Lariat
my original wheels are these. and I can assure you, there is a difference. I measured them.
and on that, I am out, the OP's question was about the suspension anyway.
