DIY dual LED Pod Fog Lights
Wasatch
UT
Ranger Supercab
Hi all,
Weighing options for LED fog lights to replace the existing OEM, I was disappointed in how expensive a simple bracket was to mount an LED in place of the OEM fog light. Upon taking out the fog light housing, I realized that the other DIY LED pod method meant sandwiching the light between a plastic bracket. Thinking long-term, I could see issues with melting the OEM housing if you go that route.
So, I went my own way:
Removed the OEM housing and fog light:
Created a simple bracket from scrap aluminum 1'' angle:
Wired up the lights:
Boom! Dual LED Fogs, wired up to use the OEM switch:
Work great and are SUPER bright (If you plan to use as fog lights on the road, Make sure to purchase DOT approved fogs). I do not use these lights in traffic.
Here are links to the stuff I used to make it happen:
https://www.amazon.com/gp/product/B07ZT62VV8/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B07MC264HD/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B01HNAT6CW/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
OFC Ranger
Jack
ZR2
My only problem with this is basically every Amazon light that is labeled fog, spot, or flood - are all just flood lights. Spots just happen to have a slightly tighter beam.
Have you tried turning them on at night then standing offset 100 feet away to see how badly your "fog lights" are spilling into the on-coming lane.
If you plan to use them like high-beams (aka no other traffic) then by all means.
On a side note, when people on here want a "spot" light, what they really mean in most cases is that want whats called a "pencil" or "laser" pattern light. I don't think most people really know what a spot light is suppose to look like. I too was guilty of this for a while.
Same concept with fog vs. flood. They are two completely different patterns.
Wasatch
Wasatch
UT
Ranger Supercab
While I appreciate your concern, this is a DIY thread for folks who may be interested in this route. There are plenty of DOT approved fogs that can be used with this method.
But in case you're wondering, I do not use these when in traffic, they're much too bright.
OFC Ranger
Jack
ZR2
I had those lights too at one point. lol They are bright.
(very old picture at this point, lighting setup completely changed)
Pirate
AK
Bush Pilot
Great write up. Now if only we could buy a fascia to fill the gap, I'd be in.
Wasatch
Wasatch
UT
Ranger Supercab
That's cool! same concept, but DIY allows you to save $100 from buying a prefab bracket. I plan to redo mine with angle iron (aluminum won't cut it long term). I like the idea of adjustability in the bracket.
How about heavier gauge aluminum? Lighter than iron and rust proof...
Hi all,
Those are the same lights I mounted to my Honda 125 =)
Wasatch
Wasatch
UT
Ranger Supercab
That's an idea too! I am leaning towards steel as I can purchase plate and bend it, cut out a slot to make the light positions adjustable... But we shall see.
