Ditch light brackets bolt on
@Robby887
Diamond Sponsor
Robby Woolworth
Las Vegas
2019 Supercrew Fx4 xlt ford ranger
Fabricator/welder
now Available I have A pillar light brackets and 20” light bar brackets. All bolt on. Check them out. www.fordrangerlifts.com
Ditch light brackets are 79.99
20” bumper light bar brackets 39.99
Call or text 702-501-3139
Email [email protected]
@Robby887
@Robby887
Diamond Sponsor
Robby Woolworth
Las Vegas
Fabricator/welder
Those ditch light brackets might be a perfect set up for an antenna!
Yeah they would work for antennas or even dune whips.
Nicolas50
Nicolas
France
Ranger wildtrack
Can you show intérior of pillar light brackets? Because not sure that europeen version of ranger raptor is exactly the same! I'm french!
Thanks
That's what I was thinking of doing by using the antenna stud as the bolt to hold the dual pod to the arm but not sure there's enough clearance between the mount and hood for the cable...
@Robby887
@Robby887
Diamond Sponsor
Robby Woolworth
Las Vegas
Fabricator/welder
Would be pretty close. Unless you can find a 90* fitting.
Stic-o
Lake View Terrace, CA
Hey Robby, I ordered some light bar brackets about a week ago from your website, but have not heard anything. Can you check on them, I'm just in LA, so they should only take a day or so to get here.
Appreciate it.
TremorOwner
2021 Ranger Tremor
I want my ditch lights farther to the side of the truck to avoid hood glare. Can you make a version that does that? These are too inward. The other designs out there have hood bolt holes that are far too big!
OFC Ranger
Jack
ZR2
Easy fix, get you some matching width flat "mending" brackets. then run those from the ditch bracket in the direction you want and attach your lights to the end.
Just an example (come in all shapes and sizes):
https://www.amazon.com/Tulead-Melding-Straight-Brackets-Mounting/dp/B07TD7TT13/ref=sr_1_21?dchild=1&keywords=1"+mending+bracket&qid=1623496494&sr=8-21
Crude visual from MSPaint:
As far as hood glare. Unless you get "pencil" or "laser" style lights, its gonna happen. You would have to run pretty long extensions of a mending bracket to get even a standard spot light not to bounce off some of the hood.
TremorOwner
2021 Ranger Tremor
Appreciate the idea. I don't want to daisy chain pieces of metal. Going to try the Diode Dynamics brackets. The eBay ones are terrible.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Is this a forum discount for the 20" bar bracket? The website says $85.
