Chime with driver door open but no key.
Airline Tech should start charging troubleshooting fees on this forum.
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
Try turning the head lights to OFF, instead of AUTO, see if the chime stops.
I have confirmed that the Headlights On - Chime is slower, the chime in the video is faster (1/2 Sec) chime vs (1-Sec) chime for the Headlights
Note: Thet are the same chime tones, just difference in speed.
Mlemos89
Mlemos89
Michael
Colorado Springs, CO
2019 Ford Ranger XLT
Field service technician
I could be talking out of my ass here but...
That sounds like the low-battery chime.
My truck never chimed like that until I let it sit for a week without driving it. The battery still has the juice to start the truck, but the truck senses the battery isn't at some predefined level to keep power to systems that stay powered when it sits. I bet you'll start getting a message on your center screen now, intermittently, saying the battery saver was engaged while you weren't using your truck.
Hey, I actually thought it was that at the dealer because the battery was bad so I had them take $200 off the tag on order for me to pick up a new battery and install it myself but sadly it did the same thing. I should have brought it right back since I thought it wasn't normal but didn't know that 100 percent at the time.
The issue is either the Ignition Switch itself, stuck tumbler - not springing back out as key is removed or the wiring has been jumped (between the power feed into the ignition switch) and the (Output - feed to the BCM)
It takes this circuit to complete for Engine Start, with key removed the (Output - Feed to the BCM should be dead) - So this at least confirms the circuit is being completed or the truck would not even start.
So, this circuit is staying - Live, and it sees this as Key in Ignition
With this truck getting repaired (New Ignition - Switch) it could be a Faulty new switch or technician missed the wiring being jumped or wiring damage that is allowing the circuit to stay live.
BS67
Brian
Nebraska
2022 Ranger XLT
Confirmed this am. Lights in auto. No key in ignition. Driver door open and no chime. Insert key and chime starts with door open.
Is it the fast chime (1/2 sec) like his video?
The headlight chime is slower but the chime tone is exact same
Mlemos89
Mlemos89
Michael
Ok I think that must be the issue, I pulled fuse 18 and chime stops right away. Also putting key in and out before pulling fuse the chime stayed the same. Thank you for the help.
BS67
Brian
Nebraska
2022 Ranger XLT
The chime is the same.....the rate of the chime is more consistent with 2nd video posted.
Not a Ranger - But here is a short video, on showing you how the Key in Ignition works, the Ranger will work on the same principal operation, except wiring is in the main ignition switch connector for Key in Ignition - sensing.
It is still using the Key Tumbler to provide the contact point to provide the ground to the BCM.
So since you are not blowing the fuse for it, the problem will be between the ignition switch and BCM - Ground Side of the circuit.
The wire with the clip in the video is the ground and it goes to the BCM, to turn on the chime, it also allows the vehicle to start and also ties into the PATS (Anti-Theft) system.
Ignition Chime Always On Problem Fix! - YouTube
