Can someone please help me, engine amd wrench icon on 2019 ford ranger raptor
Rod
Rodolfo
Philippines
This icon started to lit up when my mileage reached 23k,i brought it to ford for oil change but after 4 days it still come on, how do o reset the oil chanhe lofe because there's no oil reset in settings menu amd also i cant pressed both the brake and acceleration without turning on the engine because it's a push start
Hi Rod,
I can not help much on a ROW Ranger, but the procedure should be in your owner's manual. On NA Rangers it is in the menu using the buttons on the left side of the steering wheel.
Rod
Rodolfo
Philippines
Hi Rod,
There's no instructions in the manual, i read something here in forums that maybe i should enable it thru forscan??
My acceleration is very much affected, slow in auto gear change/shifti so what i do now is put it in manual mode and shift manually
Rod
Rodolfo
Philippines
And by the way is this really for the oil change because ford pass oil says 0%
Since Ford did the oil change why don't you just bring it back to them and let them reset it and check it out? If you want to do it yourself just Google 2019 Ford Ranger Raptor owners manual and you'll be able to read in online.
gov cheese
j
Grooovvy!
2019 ranger xlt super cab
Seems to have the same procedures as 2015 Ford focus below.
1. vehicle off
2. press and hold in brake and gas pedals
3. DO NOT start only turn key to 'ON" position --should reset oil life in 20-30 seconds
4. turn key to off release brake and gas pedals
5. start vehicle
try one of these for a T6 ranger
Rod
Rodolfo
Philippines
Thank you for the replies, a frirnd have a scan tool this is yje error can someone help if this is easy or should i bring to dealer??
