Can Ford tell who's tune has been loaded?
JasonTremor
2021 Ranger Tremor XLT
On the last page is their legal out for all liability for all Ford Performance Parts.
Dgc333
21 Ranger Lariat
Yes. The warranty begins from date of first service.
Not sure what you mean. But to clarify the FP tune warranty covers the car during the cars first 3 years or 36 months not from the mileage/time that you install the tune.
So if you buy the car and it has 5 miles on it and you immediately install the tune you would be covered for three years from the date of sale or to an odometer reading of 36,005 miles. If you installed the tune after you purchased the car when it had 30,000 miles on it then you would have 6,000 miles of coverage.
Also, the FP tune does not shorten the power train warranty. The 5/60 power train warranty becomes just like any other after market tune if you have a failure and it is determined to be caused by the tune the claim could be denied but the next failure may be covered. That being said I have never heard of anyone having a power train failure in in the 5/60 portion of the warranty denied because they have the FP tune.
Incorrect, it states in the paperwork/contract from ford performance that it goes off the original inservice/start date of the warranty meaning that when the vehicle was first purchased by the first owner. Meaning that if you are the second owner there is a chance that warranty is close to up as it is. Onve the truck passes 3 years or 36,000 miles all together the warranty is up. Its a wonderful thing.
Also it does take the factory powertrain warranty down to 3 year 36,000 as well. Reading tue fine print and talking with Ford Performance and Ford I have verified this a few years ago.
Dgc333
21 Ranger Lariat
That's what I said. Didn't make the distinction about being a second owner though.
And it is pretty clear to the point that they put it in bold that your warranty stays intact for any failure not caused by the FP part. I would take anything you are told by the FP customer service folks with a grain of salt.
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
This is what the Ford Protect Plan says about mods:
e) Failures caused by: (1) alterations or modifications of the Vehicle,
including the body, chassis, or electronic components, after the
Vehicle leaves the control of the manufacturer (2) any part
designated for “off road only’’ that is not installed by the
manufacturer, including, but not limited to, lift kits, oversized
tires, roll bars, and performance enhancing powertrain
components; (3) tampering with the Vehicle or the emissions
system and components; (4) installation or use of any mechanical
or electrical part not approved, certified or authorized by the
Vehicle’s manufacturer or any Failure caused by after-market
(non-factory approved) PCM reprogramming.
Jackpot Tremor
Bill
Orange County, CA
2024 Ranger Raptor / Azure Grey
Self Employed
so if I'm understanding correctly by this "legal jargon".......if my motor/trans in my NON-ASE Ford Performance Tuned Ranger Lariat Tremor takes a dump at 100,00 miles my Ford extended warranty will probably deny it even if it's not the fault of the tune install "because they can"........BUT......if the a/c system takes a dump at 100,000 my Ford extended warranty probably should cover it??!!........even though technically Ford would have to "prove" the tune caused the failure (of the motor/trans) (which they will say no matter what to get out of a big ticket item like a motor/trans and you can't fight Ford)......
again, I didn't buy the extended warranty for the motor/trans but more for the other stuff which still can break and add up to thousands of $$$.......I'm not too worried at all about the Ford Performance Tuned motor/trans because it seems to be able to handle it and has a great track record.......
rdwarrior52
Southern California
2021 Ford Ranger Lariat
I had a 2019 Mustang with the Ford Performance tune that I had installed myself. About 1.5 years later, I had a head gasket failure. It was covered under the power train warranty and there were no questions asked about the tune from either Ford or the dealer but your mileage may vary.
