Pm980
- Thread starter
- #16
Update
So I noticed that this bolt circled blue was loose, I am thinking maybe the mechanic could have connected the accessory back to the battery negative instead of grounding it to the chassis ( as mentioned by @RangerBill) as this accessory cable was also damaged but I don't know where it was connected before they did the timing cover.
I have moved it to the loose bolt and tightened it, reset BMS again and cleared fault code but unfortunately the issue persists. I then tried disconnecting the Accessory all together reset everything but the issue continues. I still get the battery charging service now light, 4x4 light and sometimes check differentional.
I can't see any loose connections as yet. The search continues!! Ranger starts fine every time even after not using it for a few days, no issues whilst driving.
My next plan is the put the original battery on an optimiser and stick it back in the truck
