- First Name
- Phil
- Joined
- Apr 3, 2019
- Threads
- 142
- Messages
- 7,016
- Reaction score
- 36,214
- Location
- GV Arizona
- Vehicle(s)
- 2019 Ranger FX4 Lariat 4x4, 2020 Lincoln Nautilus, 2005 Alfa Motorhome
- Occupation
- Engineer Retired
- Vehicle Showcase
- 1
Hi Larry,I bit the bullet and spent the $99 for the NVH App for Android. I'd been feeling vibration at 70MPH recently and attributed it to needing new tires. After new rubber, alignment, balance and then road force balance I was still feeling the vibration. The NVH App indicated drive shaft issues. My experience with service techs diagnosing subjective issue like vibration was going to turn into a debate so $99 seemed like a good investment to have some additional evidence to support my case. At first dealer's tech reported could not duplicate issues (seat of pants) diagnostics and I had to remind them it was at 70mph that symptoms appeared. So they redid the test drive and tech detected vibration. Next step was to do another test drive with NVH sensors. Dealer says results indicate all tire related vibrations! Uugh , here comes the they said/they said conundrum between Ford dealer and tire dealer.
I was able to convince Svc writer and manager to do a wheel swap test drive with wheels from a new ranger to completely rule out vehicle drive line issues. Waiting for them to get around to that in the next day or so.
Will let you all know how my saga plays out.
What frequency do you show on your NVH software? There will be a huge difference in driveline frequency at 70mph than tires and should guide you. Tire balance is 1st order, Tire out of round (ovality) is 2nd order and driveline will be a magnitude above this by about 3.73 or what the rear gear is. Going by the engine as 1st order imbalance, 2nd order is shaking forces of a 4 banger and if driveline it will also be 2nd order as it is the frequency of a u joint at 8th gear which is one to one...then tires will be some 3.73 lower frequency that that for tire imbalance and half that for ovality... Hopefully between you and the dealer you can radar in on this.... Tire swap is a good idea in the meantime...
Want to play around a bit....use your NVH software and get a capture of the vibration. Then slap a hose clamp or two with the heads together side by side...now see what your NVH software reads as you have grossly imbalanced your driveshaft... This will start to give you a feeling for sensitivity of the software and to some extent calibrate your assometer too...
best,
