Am I on the right track?
Gibs45
Gibs45
Redondo Beach
2021 Ford Ranger Sport 4x4 Cactus Grey
Sales
FYI. Spacers are gonna make it worse if its the crash bar.
i went to a +25mm rim with stock tremor 265’s and ive worn a groove in the plastic cover on the drivers side from when i reverse.
Thanks for the note. Plan for me is to just take these spacers off and deal with that little plastic rubbing for now. Will likely end up taking the plastic off/adjusting the crash bars a little as needed. Thankfully it’s only a slight rub with the factory rims.
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
I don't know if it was mentioned but you can loosen the bolts for the crash bars and push them out then retighten them. Did the trick for me on my Tremor when I added 1.0" wheel spacers. Removing the plastic was not enough till I adjusted the bars.
Prior to doing that I had no rub going forward but in reverse I would get rubbing, in particular when the wheel was turned to the right and going in reverse. Could only get about 85-90% of my steering wheel travel till I did that.
Gibs45
Gibs45
Redondo Beach
Sales
Good to hear that worked out for you even with the spacers! I’ll be adjusting those Crash bars soon. Luckily the rub is extremely small. Thanks for the note
