revbevis
Ava, IL
2019 Ford Ranger XLT SuperCrew Chrome Package
Got this finished up today. Its from an explorer sport trac. Not bad for $50(total, and that's Canadian too!)
Did you have to cut it down in the middle? If so, is that the only mod. you had to make?
Glocker
Boca Raton
weasel1
Pembroke, Ontario
Nuclear Operator
Yup, it had to be cut. Gorilla glue and 1.5"ABS pipe took care of the rest. I had to Dremel out a tiny bit of plastic so my pivot would lock into place. Depending on how you make the pivot, this may be unnecessary. Other than that, I filed the "feet"a bit (the rests that it sits on when the tailgate is up). I had to do this because the top bar was resting directly against the tailgate.. I'm convinced this has to do with the bedliner.
Tringram19
Trey
Maryland
2019 Ford Ranger FX4 1989 Ford Ranger STX
Didn't stick for me either and I selected the Raptor theme. Selected it again, turned the test settings off and cycled the power, opened/closed the door a few times and now it seems to stick.
So you just selected it twice and cycled the power ect a few times and it stuck. Has it gone away yet or is it still sticking?
weasel1
Pembroke, Ontario
Nuclear Operator
Its gone. Checked it the next morning and it was back to stock.
Tringram19
Trey
Maryland
Dang. Guess forscan is going to be the way to go then.
Although I think if you change the setting to enable testing it will stay on the menu and you can go and change it every time you start your vehicle. If you wanted to go through that
Yellowtoy
Australia
2019. Ranger Wildtrack
Crane Operator
Thats it Tringram 19
Way easier doing it that way...
MaxE55
Max
Indiana
Maintenance Tech
Got new Coverking leatherette seat covers. Going to install this weekend. Really impressed with the quality.
Jake596
Jake
Nevada
2019 Ranger XLT/2013 F-150/1976 F250
Take a picture of them installed, if you can. I'm in the market for some good seat covers.
I also put in a set of CoverKings and they are worth the $$, Very good fit, almost perfect, cut for your Ranger and a ton of different styles and colors. I found them to be cheaper thru a distributor on Ebay... Took about 2 weeks to get my fronts and about 4 weeks to get the rear..........
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
Does the rear cover have cutouts for the baby seat latches?
Jake596
Jake
Nevada
Mmmm I believe it did, not a 100% sure tho... It has a full cut out and cover for the cub holder arm rest also.
