AC 120 volt inverter
canyonslicker
Andy
2021 Ranger Lariat
65 YO Juvenile Delinquent
Hi all,
I would like to know where the DC supply input to the AC inverter in the center console is located.
I’m looking to connect a ham radio to that point. Probably eliminate the inverter.
thanks in advance.
NotBudule2
Robert
21 Ranger
canyonslicker
canyonslicker
Andy
2021 Ranger Lariat
Grandaccess
Robert
Binghamton, N.Y
2021 Ford Ranger XLT FX4
Computer Consultant
Thanks it looks like I’m going another route.
the fuse probably aint good enough, I blew mine within the first month, do it the right way and run a wire right to the battery for communications equipment, put your own inverter in too...
73s W4RFD
canyonslicker
canyonslicker
Andy
2021 Ranger Lariat
73s W4RFD
Thanks for that. 73s KO6KPZ ..
JonB
Elmhurst, IL USA
2019 Ford Ranger XLT
The inverter is rated at 150 watts. Assuming 100% efficiency that would translate into DC wiring that could handle about 12 amps. Now, if you’re running a 50-100 watt radio that may not get you by.
Also, the wiring in the cab may be susceptible to noise generated by all the electronic devices in there. Better to wire directly to the battery with wire heavy enough to carry the electrical load of your radio. I did that and I can tell you it’s a pain in the tail getting through the firewall.
KC9OO
