SOLVED: Excessive Wind Noise Above 50 MPH, Window Gasket Replaced
C.moore01
Colbey Moore
Kermit Wv
2017 escape 2019 ranger
Anthony
Anthony
Connecticut
COO
I did notice wind noise coming from the rear-seat side window area on my SCrew at highway speeds. It was loud enough to where I thought the window was cracked open. I don't know if it is a vortex caused by the side mirrors or what, but it is a bit noisy. Not world ending, but enough to notice.
Anthony
Anthony
Connecticut
COO
To follow up on this, I retracted my mirrors for a second while driving into work at highway speeds this morning and it didn't assist in reducing the wind noise.
Lrtexasman
Larry
Tahoe/Tundra/Fusion
When the Ridgeline rolled out there were similar complaints for a variety of reasons. Some of those issues may apply here, including the rubber gasket sealing the door or the one sealing the window may not be installed or secured properly, also the door alignment may need adjustment to seal properly. For testing purposes put blue painters tape of the door crack and if necessary the window/door area to see if you can stop wind noise. That will tell you if it’s one of the two issues, both of which are easy fixes.
Anthony
Anthony
Connecticut
COO
I'll give it a try, thanks!
Krzydmnd
Pennsylvania
2019 ranger Xlt
Yeah I've not experienced anything out of the ordinary in 2k miles so far. I had a weird whistling one day on the highway but it went away on its own. And I am very sensitive to cabin noise, the slightest rattle or rub or squeek drives me crazy. So far, nothing to complain about with the ranger!
Reactions: Ric
C.moore01
Colbey Moore
Kermit Wv
Just a update I have found the problem and it’s going to the dealer Wednesday .. it’s in the rubber seal that’s around the drivers window track next to the mirror .. I’ll take a picture and upload it and circle the area .. it’s somewhat lose fitting but you can press on it and make the sound go away
Anthony
Anthony
Connecticut
COO
Glad you got it resolved! Can you upload the pic with the area circled? I'd like to take a look on mine as well. Thanks!
C.moore01
Colbey Moore
Kermit Wv
I could take my fingers and press and pinch on the circled area and make a huge reduction in wind noise .. my wife from the passenger seat could even tell
Anthony
Anthony
Connecticut
COO
Thanks for the pic!
Floyd
illinois
I'm not saying that there is no problem, but I have owned Econolines and an Aerostar also several convertibles.
A light coating of silicone spray or Teflon spray on all door gaskets does wonders to help them seat and quiets them quite a lot.
jhgr
Cumming Ga.
ford
Has anyone found the solution to wind noise, which sounds like its coming from right rear door or window?
I tried putting tape around rear door and window, but couldn’t tell any difference. I have just about decided it’s just the nature of the beast since so many people are experience the same problem.
